07-06-2008, 11:21 AM   #1
Quick question regarding my just received FA20
Another question bordering on the ridiculous but here goes...
I received my (used) FA20 a week ago but only now have I had time to mount it. I am wondering if the small wider-opening extension on the end is the hood? I only have my FA50/1.4 to compare it to & it does not have the small wider-opening extension at the end (no hood I guess?). With not much effort I thought I try unscrewing it but it did not budge. Maybe I need to turn harder?
It looks exactly like the pic below:
07-06-2008, 12:07 PM   #2
Stratman's Avatar
I don't know if it is a hood, but I have a sigma lens with that type of hood, and could never get it off. What you need to do to get it off, is to use as LITTLE pressure as possible. If you use too much, it binds the hood, and it will never come off.
07-06-2008, 12:18 PM   #3
TourDeForce's Avatar
THAT IS NOT THE HOOD!!
That is part of the lens. Please note the filter threads. A lens with as wide a perspective as a 20mm won't have much room for a filter, much less a hood before you see it in your pictures. The filter threads had to be extra wide because the extension of a filter ring may put shadows in the corners of the photo. Cropped image area of the smaller sensor means you can get away with it in digital, but not on the old film bodies.
07-06-2008, 12:42 PM   #4
Check the Pentax Forums Lens Database, the hood which screws into the filter thread is mentioned. Your copy didn't appear to come with the hood.
07-06-2008, 01:24 PM   #5
monochrome's Avatar
FA20/2.8 Lens Hood
Here is the hod that goes with your lens - available special order from B&H in New York - or maybe you can find a used one.
Pentax | MH-RB67 Metal Lens Hood (67mm) | 34130 | B&H Photo Video
Pentax MH-RB67 67mm Metal Lens Hood (Round) for 20mm FA & A-Lenses
Here is a full description of your lens - scroll down to see the fitting hood description.
FA 20/2.8
07-06-2008, 04:38 PM   #6
Thank you all!
extension, fa20, hood, k-mount, pentax lens, question, slr lens
K-X Quick Question NecroticSoldier Pentax DSLR Discussion 6 03-01-2010 02:11 PM
Quick question ACImages Pentax SLR Lens Discussion 7 03-26-2009 11:56 AM
Quick Question Fl_Gulfer Post Your Photos! 2 04-16-2008 05:19 PM
Quick question. magnum1 Pentax DSLR Discussion 9 01-03-2008 01:46 PM
just a quick question little laker Site Suggestions and Help 5 09-12-2006 06:32 PM
All times are GMT -7. The time now is 03:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
