Once someone has K-1 they can do a test - take one shot in FF mode, one shot in APSC mode, without changing the lens, aperture or focus.
I think that a) lens' focal length and aperture are a lens property, and they will render the same image (with the same focus) regardless of format (FF, APSC, MF); however b) sensors have different resolution, different size pixels, which might have various consequences. This is why I think hyperfocal rules from the film days are slightly outdated, and that it makes sense to use a stop different aperture (focus as if you are using a stop wider aperture). But that is just my limited, unscientific, definitely not thorough experience.
Originally posted by jatrax 2) On DA lenses such as the 15mm and the 21mm were the marks designed for APS-C and thus should be used as is or do they also need adjusted?
This would be a great question to ask Pentax. And not just their marketing department, but the engineers. What exactly was their standard for the markings on the lenses? Then a K-1 test to check the answer empirically
