Originally posted by audiobomber The problem with adding the HD TC is not with IQ. Auto-focus takes a hit, and so does aperture. A 60-250 with 1.4X TC is definitely compromised vs. a DA*300.
I'll just avoid the big long explanation and stick to the talking point.s
Check your library, so what percentage of your images are taken at less than 250mm... do you really want to give those up?
Personally of the 1900 60-250 images in my library and 600 of them are taken at 250mm, and many of those are uncropped. Will I give up 4/5s of the images I take with this lens to get better performance on maybe 20% of the images?
Despite what is said above, the 5.6 of the 60-250 with the TC is not a big compromise. I often just leave the TC on the camera when I shoot wildlife. It has to be pretty dark before AF becomes a problem and i want to take it off. And darkness presents all kinds of other problems.
You can't really look at replacing the 60-250 with a prime. You're going to need other lenses. SO, to keep equivalent IQ, you're going to need a 50-135, a 200 and the 300 as a minimum. Maybe your lens selection is such that you have every thing covered. But there isn't a lot available for Pentax that covers what a 60-250 covers with excellent IQ. You need to consider what else you'd need to buy if you go this route.
Either lens is great at what it does. The 60-250 just does a lot more.
There used to three forlenses 200 and over, the 60-250, the 200 the 300. Now there's the 150-450 and the 70-200. The 300's niche in the pentax world has gotten a lot smaller.
But if you need 500, the 300 with the 1.4 is still the best way to get close without robbing a bank. But if you're me, what you really want is the 150-450, which also plays nice with the TC. With 450mm ƒ5.6 and it's ring motor, it's just a different class of lens.
You can probably tell, I've sat and had this conversation with myself probably 100 times.
Right now if I had a 60-250 and 300, I'd sell them both for a 150-450.
But, I'm saved by having my relatively inexpensive A-400. I can't get much for it it terms of selling to get a 150-450, but it gets me long when I really need it, and unlike the 300, is pretty a much perfect companion of the 60-250. 300 is too close to 250 to be much of an upgrade. Especially since I have an F 70-210 when I want close focus.
