Originally posted by Des I was agreeing with you completely up to this point Nicholas. And I agree with the tenor of the thread. But there is a point that many enthusiasts reach where you need specialist gear, and it's often (realtively) expensive. Wildlife lenses and macro are examples. Yes people can get good results with a consumer xx-300 zoom when the light is good and the subject not too far away, but for shooting distant subjects or in poor light there's no substitute for longer and/or faster.
To go back to your car analogy, most people don't need a 4WD with low range, high clearance and a snorkel, and some people have those things just for an image of themselves. But if you drive on serious 4WD tracks and ford rivers, believe me you do!
Yes there is too much obsession, and unrealistic expectation, about gear. I don't suggest that a $2k lens will make someone a good photographer. And if it doesn't produce good photos it's rarely the fault of the lens. And yes a really good photographer can win prizes with a smartphone. You can see countless fine photos here taken with <$100 lenses and cameras several generations old. But there are times when a particular shot just needs particular gear.
That's right, the question could be why insisting on taking that shoot or on that practice as "necessary".
As well as the car analogy, do you need to go on serious 4WD tracks and cross rivers all the time ?
And I mean I checked the thing when I decided to go to Iceland for a dozen days. We could rant a nice 4WD or a tourism car. Then the guides explained that to do it and be safe, you had to have at least 2 groups with at least 2 cars, really know your stuff and so on... Otherwise you could very well endup in the car, being taken by the river heavy flow and found dead month later.
The thing is we rented a normal car, we stayed on normal roads and when we decided to go on the glacier, we paid for somebody to drive us. Their vehicule had wheels the more than 1.5meters high. I mean would we have rented (or brough by boat for that matter from europe) a classical 4WD this would not have fitted anyway.
If you like macro there tamron 90 for you or any lens with an apperture ring with extensions rings added. This is still cheap.
If you really want wildlife, yes you might need expensive gear... And well even, I understood that's a compromize between the key wildlife shooter capacity to be more near your subject to get better shoots and having better gear that significantly more expensive.
I am going to Tanzania (rather than Kenya after all), we settled for this september in the end, and I decided to go for a 55-300. I have seen picture from some forum members... The 55-300 does quite a decent job. For a one time event. The 55-300 is good enough. Yeah I could have decided for a 150-500 or whatever but then I'd have to be sure I use it for several outings a years, otherwise it make no sense.
There is great gear, it does help but it make sense only if you really plan to use it.
