Hi
I have recently purchased one of these, hoping to make it my go to Pentax 50mm. The example I bought has beautiful optics and is cosmetically near mint. But unexpectedly it has two issues...
1) The 'A' contact does not raise up when the ring is set to 'A' and
2) The AF screw drive slot does work when you turn it manually with a screwdriver but it does not appear to make contact with the AF SLRs I have tried it with (K-3 and MZ-5n)
Are these two issues connected? I expect that they probably are but what would be the reason for both the 'A' contact and AF drive slot not raising up higher? The other four mount face contacts can be pushed down a bit with the tip of a small screwdriver but the 'A' contact pin does not give at all.
Any advice would be hugely appreciated!
Simon
