Originally posted by bdery the FA limiteds still sell well, and are still, nowadays, regarded as being among the best there ever was.
We don't know how well they really sell, globally. We just know they are popular on some forums. And best there ever was? Sure, they are great in many ways, but on digital they have some purple fringing, CA.. and then there is the problem of lab test reviews. Lab tests would show them as "weaker" than some other, modern lenses. (sure, the lab tests don't tell the whole story, etc. etc. but if you want to sell lenses, you need that) And its not just sharpness, but longitudinal CA, lateral CA flare resistance, purple fringing.. and correcting one of these can cause problems in other areas. Sharpness and CA standards are very high with pretty much all modern primes, much higher than they were 10, 20 years ago.
Originally posted by bdery Why?
Barrel design cannot be the same as it was. Materials have evolved. You need extra space for different AF system. Not to mention WR, QS.. each of these would require additional changes. Will the barrel stay metal or go plastic? Probably a mix of modern materials.
Originally posted by bdery Not necessary. If you must (not sure you do) just make the current ones rounded.
Yeah, but rounding aperture blades is not that easy. They need to fold correctly, they still need to cover the precise fractions of entrance pupil.. there is a reason why rounded aperture blades are only appearing on the market in the last few years. They are technically more difficult to design than the straight blades of the past.
Originally posted by bdery A modified production line. Most would remain the same.
We don't know if the FA limiteds are in production at the moment. Pentax makes lenses in batches, so the production line might be busy with another batch, of other lenses. Also, Im not sure if this thread only discusses FA limited trio, or other FA lenses that are available as new (FA 35mm, 50mm) or even FA lenses that were discontinued a while ago. Some of those would need a bigger investment for an update than others
