Originally posted by pathdoc What are you currently using at the short end, below 50mm? If you've got an 18-55, 16-45, etc. etc. you pretty much have your needs covered. In those circumstances, if I were buying a backup superzoom to cover everything with one lens, I would go for either the broadest focal length range available in K mount (18-270, I believe, these days) or the DA18-135 to offer a weather-sealed package for if things turned bad on you.
If you have the 55-300 and ONLY the 55-300, and are looking for something to cover the wide end, 18-200 may be a bit too much of an overlap.
Right now, all I have is the 55-300mm WR, so I have a huge choice of things to consider for landscapes etc. I bought the K50 mainly for use with the 55-300mm.
---------- Post added 03-26-16 at 05:45 PM ----------
Originally posted by DogLover I have owned the 18-200 before. My wife used it. I can tell you it is a definite step down from the 55-300, IQ-wise. You'll mainly want to shoot it at f8 to keep things looking decent.
Thanks for the user comment. I think I'll pass on it if the IQ doesn't measure up to the 55-300mm.
Jack
---------- Post added 03-26-16 at 05:47 PM ----------
Originally posted by BigMackCam Hi Jack - I haven't used the Tammy 18-200, but I have used other superzooms, including the Tamron-derived Pentax DA18-270 and currently the Sigma 18-300, so I hope I'm a little bit qualified to comment...
Do you really need that superzoom range? Optically, they do not deliver the same results as the better more-limited zoom range lenses. Your 55-300 WR is a great lens... how about spending the money on a fast wide-normal zoom like the Tamron 17-50 f/2.8, Sigma 17-50 f/2.8 or (more expensive) Pentax DA16-50 f/2.8? One of these would fill in the range you are missing and give you excellent IQ for landscapes, as well as offering a lot more scope for lower-light photography by using the wider aperture settings. Or... have you considered using the 55-300 at the wide end and taking multiple shots (hand-held or tripod) to create stitched panorama shots? This works extremely well for landscapes, and is something you could try without spending extra money. There are plenty of software options (some of them free) to create stitched panorama shots...
As I said, I have and use the Sigma 18-300 (and still own the Pentax DA18-270 - which is fine, but the Sigma is better). The range is undoubtedly useful, but unless you really need it for convenience, this type of lens is rarely the best choice...
Thanks for all those suggestions. I'll look into all of those lenses!
Jack
