Originally posted by nomadkng ok, maybe someone far wiser than me can explain why the FF MTF was done at 20 lp/mm and the APS-C was done at 30 lp/mm?
from other sites, such as Sigma, Tamron and even Pentax, usually it's 10 and 30.
but if I compare the 30's, I've seen a lot better results, with Sagittal "scores" in the 75ish-80 from several sites.
the charts on this site put them in the 50's.
that would scare the bejeebers out of me if I were thinking about plunking down 1700 for this lens.
attached is the sigma 50-500 mtf which is a lens known as decent but not stellar. when comparing the green sag (solid) (30 lp/mm) with the blue Sag (solid) (30 lp/mm) from the Swedish results, it seems the Sigma is 20-30% better at resolving than the Pentax. I find that very hard to believe.
so while you're at it, explain to me what happened in this comparison. I'm actually asking so I can have a better understanding of lens comparisons. I know there can be several variables to MTF charts, but they shouldn't have THIS much discrepancy, surely.
The Sigma MTF charts are theoretical, better than in reality. And the one's at Objektivtest.se are actual measurements. The Sigma 50-500 mm is in fact nowhere near the performance in that chart. Also note that the 30 lp/mm at Objektivtest.se show performance just for APS-C, so they stop at a radius of 15 mm, whereas Sigmas show full frame.
I think the reason why they measure full frame at 20 lp/mm is becasuse it's a frequency that represents both contrast and resolution. 10 lp/mm is mostly about contrast. 30 lp/mm is probably chosen for APS-C because it's a smaller format that requires exactly 1.5x higher resolving power to compare to full frame. 1.5x20 = 30.
