Originally posted by tlerequiem Thanks Edmundrt and BigDave.
Very helpful. I didn't found any different on my k-01, perhaps, it is mirrorrless camera so stopped down is not necessary for k-01.
Just one question, which way is set to auto stop down (turn to left or turn to right)
Many thanks agian guys.
Hi
You cannot use it on DSLR with auto-function, that only works with the older m42 mounts. It needs a pressure plate inside the mirror house that presses a pin on the rear of the lens just prior to opening the shutter. this pressure plate was first seen on the Asahi Pentax K from 1958.
So to use it on modern cameras, you must manually twist the aperture ring to the desired f-stop, press green-button on the camera to get the proper exposure and then fire off the shutter.
When you move the handle to the left, you "cock" the automatic function. To release it without an older SLR with the mentioned pressure plate, you will manually need to remove the lens from the camera, locate the pin protuding from the rear ring of the lens and pushit. that should release the diaphrame.
Good luck! You'll love the really special creamy bokeh of this lens at f2.3
