04-04-2016, 08:49 AM - 4 Likes   #1
normhead's Avatar
IN answer to the question "Can a DA*200-f2.8 handle stacked TCs.
K-3 Stacked 1.4 and 1.7 TCs
ƒ8, 800 ISO, AV
While I realize the true test of a lens is distance, not close ups, the short answer is yes, it does, it's awesome. So, in good light, I present 476mm and ƒ8 with the 1.4 TC next to the body and the F 1.7 AF converter in the middle.
It would appear the problems I've had stacking in the past were caused by not having an ƒ2.8 lens to start with. The other thing that comes to mind is, this package, going to 476mm and ƒ6.3 wide open, is a fraction the size of a Bigma. Not only that, starting at ƒ4 with my 60-250, this combo doesn't work well. My maximum reach with the 60-250 and 1.7 is 425. The maximum reach with the 300 is 510. Essentially it looks like I'm going to get all the performance of those two lenses well as the Bigma and various 500mm zooms. Compared to anything else, of equal range, this is a joy to carry, and these images are all taken hand held.
04-04-2016, 09:07 AM   #2
Nice,
and how is the AF ?
Is there an issue in case of short distance ?
04-04-2016, 09:28 AM   #3
jatrax's Avatar
Norm, which 1.7 TC? The Pentax one?
04-04-2016, 09:30 AM   #4
How far away from you were the subjects?
This is great! The only issue (and depending on what you're shooting and where, it may not be one) is that the DOF seems to be really, really thin.
04-04-2016, 09:57 AM   #5
normhead's Avatar
QuoteOriginally posted by chrisfer Quote
Nice,
and how is the AF ?
On images like this and the smaller K-3 AF points, I lifted the camera and the AF was instant, from the bird in front to the bird in back, however if you go beyond the range of the F-1.7 AF converter, you have to manually focus, and then start over, so it's either really fast or really slow.
Here's everything here.
QuoteOriginally posted by pathdoc Quote
Between 12-15 feet.
Thin DoF is pretty much a function of long.
04-04-2016, 10:13 AM   #6
Interesting... so the DA converter and the lens are not doing the focusing, the 1.7 sandwiched in the middle is?
04-04-2016, 10:24 AM   #7
normhead's Avatar
Yes.... thats the way it works. I guess someone could also try two 1.4 TCs for full AF and less magnification, I just don't own 2 1.4 TCs .
04-04-2016, 10:59 AM   #8
QuoteOriginally posted by SBeck Quote
Which carries its own advantages, as the 1.7 is "seeing" an f/2.8 lens, not the whole shebang that the in-camera AF would have to cope with. How does all this go down with quickshift?
---------- Post added 04-04-16 at 15:30 ----------
One would have thought distance would minimise that, but yeah, not at the ranges you're talking.
04-04-2016, 11:07 AM   #9
normhead's Avatar
The quick shift is very nice. I'm not sure if a non-quick shift lens would be any different. Taken resting on my kitchen window, instead of the blind.
Here are a few more images from 100 feet away, uncropped
DA*200 Stacked 1.4 and 1.7 TCs/
What's everyone looking at?
Cropped to 2300x 1900 to show that I do have a redwing blackbird hanging out with the grackles.
Probably wrapping up the day, DA* 200 plus stacked TCs day, a few more from the blind, farther than the first images much closer than the kitchen window images.
All the usual suspects
Plus the first Junko of the year.
04-04-2016, 11:25 AM   #10
zzeitg's Avatar
This would be very interesting. We would get 392mm with f5.6.
Small size, lightweight set. Just perfect as walkaround combo.
One question concerning your test. You mentioned it resulted in f8. But why?
f2.8 x 1.4 x 1.7 is 6.66, so I would expect something like f7.1.
04-04-2016, 11:36 AM   #11
Digitiser of Film
BigMackCam's Avatar
Norm - I'm astounded by the results. I really wouldn't have thought stacking TCs would allow for such nice IQ. Great stuff!
04-04-2016, 11:44 AM   #12
QuoteOriginally posted by zzeitg Quote
Two stacked 1.4 would also maintain the weather sealing through the whole thing (and transmit focal length to the camera, I believe?). Although putting the 1.7 in the mix is an easy way of using screw drive instead of SDM on the 200. Wonder how either of these combos is at tracking moving subjects at a distance?
04-04-2016, 12:40 PM   #13
normhead's Avatar
Because it's almost 500mm and DoF is an issue. Also, I have no idea what that means. Opened the lens right up and it said said ƒ4.5, which is probably the ƒ2.8 and 1.7, but did not include the 1.4 SO I was stopped down at least 1 stop. I just guessed ƒ8. The camera said 5.6.
I have seen so many poor results with stacked TCs, I only did this because someone asked me to. I think the difference between myself and others might be, starting with a high quality ƒ2.8 lens, and then adding two high quality TCs.
I so rarely have an opportunity for BiFs it may be a while before I get a chance to test this.
04-04-2016, 12:49 PM   #14
I'd be more interested in sports field distances than birds in flight, personally. Either way, I'm impressed and sorely tempted to spend some more money that I don't have.
04-04-2016, 01:33 PM   #15
Digitiser of Film
BigMackCam's Avatar
Indeed, there are lenses and there are lenses I wouldn't even think to try this with anything other than an excellent lens, but you've demonstrated that if you work with decent glass, the results can be very good indeed. Honestly, if a new user had come onto the forum showing these results and claiming they were from a stacked TC setup then, frankly, I'd have been sceptical...
answer, bigma, k-mount, lens, pentax lens, slr lens
Anyone have a bridge camera with constant f2.8 willing to answer questions? Kartynas Canon, Nikon, Sony, and Other Camera Brands 33 06-09-2014 09:34 AM
Super Wide II, canīt handle f2.8 Pontax Pentax SLR Lens Discussion 10 05-17-2014 08:33 AM
Ridiculous Question -- But I Can't Find the Answer John Smithwick Pentax Medium Format 4 03-14-2014 09:22 AM
"Sail To The Stars" @ Milang South Australia (Star Trails with the DA 14mm f2.8) Adrian Owerko Post Your Photos! 15 04-07-2008 06:11 AM
All times are GMT -7. The time now is 10:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
