perhaps i'm doing something wrong. i'm not entirely sure. i recently got a rokinon 85mm lens (perhaps that was my issue) and whenever i'm using it, however i'm using it, i cant seem to get the image sharp enough. they look sharp due to the crazy bokeh. however, the subject on the other hand doesn't seem to ever get sharp.
so i thought it was a calibrating issue as i've heard others talk about their samyang/rokinon/bower/etc lens not calibrated properly.
i got a sypderlenscal and calibrated my 50mm. it didn't need adjustment at all.
then i tried the 85mm and it seems to not like any of the settings i dial in on the camera for it.
heres what i'm using:
a spyderlenscal on a flat table
a k5 body on a tripod
lens attached to body at about 5 feet apart
the lens is set to wide open
i have it set for 2 second timer
i manually focus till i hear the beep. i confirm with my eyes if that is the sharpest it will go and i take the pic
when i close examine it i get variable results that i cant seem to replicate. i first see the entire image a blur. then without having to change anything, i take a second pic (mind you, i didn't change the focus or anything) and now, somehow the pic is sharper (but still not sharp). i try to take a third pic, and its somewhat similar result and it seems to be front focusing. so i adjust the calibration on the body, and refocus again and try taking the pic. it seems to either focus back, or forward, at random intervals. i zero it out, and it back focuses. i adjust it and it front focuses. i zero it out and its still front focusing. i adjust, and its back focusing. then randomly focuses just right, but not spot on.
i try the pentax 50mm 1.4 again and it seems to focus just fine (granted, not as sharp as i would like, but sharp enough to get me by)
perhaps i'm in the wrong to trying to adjust a manual focus lens? perhaps a manually focusing lens can not be calibrated? perhaps its my aging k5 body. i recently went on a trip and took several pics and came across the same issue. some pics are just fine. others are not. i was using multiple lenses on the trip, not just one. so perhaps the body itself is the issue?
for what its worth, i am able to get pics like this wide open using the rokinon 85 hand held.
its almost focused, but not quiet. and perhaps its due to the extremely shallow depth of field, where only his ear is in focus?
anyone care to help with this?
