Originally posted by audiobomber That's not very realistic Norm. The 16-45mm is already sharp at f4 and 16mm. It reaches maximum sharpness by f5.6 at any focal length. The 18-135 is pretty terrible at f4 and 18mm.
You're just looking at the CA number. Most owners think very highly of the 16-45, and it is rated as a top zoom for K-mount by DXOMark.
Best zoom lenses for the Pentax K-3 - DxOMark
It definitely belongs on the OP's list for consideration, IMO. The 16-45mm is head and shoulders better than the 18-55's I've owned. For my needs though, my 18-135 and Sigma 17-50 are a better fit.
My bad, I was talking about the 16-85, not the 135.
Those DxO numbers are just weird. They don't correspond to the Photozone numbers or anyone else's numbers. But, DxO mark rates almost every Pentax lens out there, but doesn't rate the 18-135 or 16-85? Probably the two most popular walk around lenses out there.
The 16-45 on DxO mark is rated 18 score and 11 sharpness.
That's identical to the HD DA 21 ltd.
Better than the DA 40, the DA*200, the DA*300, the DA 15 ltd. right behind the FA 50 macro.It's sharper than the 100 macro , the SMC DA 21 ltd.and same sharpness as he DA 35 2.4, DA 70 2.4, FA 50 1.4,
According to DxO it's a great lens. Yet you look at photozone and it's a great value for the money lens, 18-135 and 16-85 class, both of those lenses beat it in some FLs and are worse in others, on Photozone, where you can see some actual measurements. But as a walk around lens 16-45 is extremely limited. And there's something fishy about the DxO mark scores. They aren't corroborated by any other site. With the 16-45 you're talking a range of 29mm and a 2.8:1 zoom ratio.. The 16-85 is 69mm and a 5.3:1 zoom range/, the 18-135 is 117mm. Compared to the 16-85 you talking about less than half the range. Compared to the 18-135 7.5:1. You are talking about 1/2 of the focal range. So less than half the range, for less than half the price. Unless you get it for $150 I don't see it as a bargain, and you're giving up WR and the ring motor.
As well, the lack of WR also makes it less than desirable for a walk around lens, ad screw drive instead of a nice ring motor like the 18-135 or 16-85. Even if the optical rating is as DxO says, and that is clearly open to dispute, there are a lot of negatives.
In fact anyone considering this as a walk around lens has to seriously consider if 45mm is long enough for their walking around. The zoom range is extremely limited. Probably the only one less limited being the the 20-40.
As a walk around lens, the 18-135 and 16-85 compared to the 16-45, the 16-45 is only half a lens. You still have to buy the other half. Like the 28-105 or something like that.
I am quite interested by the IQ however. DxO says one thing, Photozone says something else, who's got a tie breaker? I tend to lean towards the Photozone numbers just because they provide an FL by FL breakdown. DxO gives you one rating for the whole zoom range. Does anyone know what that actually means?
