Originally posted by ScooterMaxi Jim UncleVanya - you've got the right idea.
Norm, if this was about landscape lenses - we would be talking about higher end prime lenses for the most part. As for regular, general uses where a zoom will be more versatile, then the need to stop down isn't a priority. It happens that my typical shooting situation often is close to f/4. For instance, it is my preferred f-stop for portrait work because faster yields poor focus on important facial features and smaller apertures don't yield enough background blur.
As for that 31mm comparison, I find it quite odd that one lens wide open is not much sharper than the borders (the other not close at all) and the two lenses are not close to consistent as to where the sharpest center area lands. It is very clear, then, that the two samples are not at all close in overall sample quality. That tends to yield the theory you're forwarding questionable, at best.
Sorry, UncleVanya - I just couldn't resist.
And if we were talking portrait lenses you'd be right. But we are talking "walking around lenses", not "walking around in a portrait studio" lenses.
It occurs to me that we have opposed theories about how to evaluate a camera, you are apparently looking at the lens at it's worst as if you will use the lens at it's worst settings.
I look at lenses at their best settings, to evaluate whether the lens adds anything to my arsenal. I'm more concerned about what lens does well , than what it does poorly. Which clarifies why we are opposite sides of this issue. The simple fact, you can say it's the worst, because at some settings it is, while I can say it's the best, because at some settings it is, and we can both be right.
In this case, you rate the 18-135 so poorly, because it doesn't do what you need it to do. My only question would be do you really think that's relevant to everyone else looking for a walk around lens. I could probably post 1000 keepers i would have missed if the 16-45 was my walk around lens.
My favourite portrait lenses would be the Sigma 70-2.8 and 50 1.7. I simply don't consider ƒ4 lenses portrait lenses. Maybe snapshot lenses.
Every lens is bad if you use it for a purpose for which it wasn't designed or which doesn't fit it's technical profile.
