04-10-2016, 12:49 PM   #1
Smc Pentax K 300 f 4 or FA 100-300?
Hi Pentaxians, I would like to ask for advice on a purchase...
I have two different proposals, and I do not really know what to choose between the FA 100-300 and the K 300mm F 4.
Now, i know that the 300mm its a prime lens, but since this is a very old lens, i am doubtful about image quality and the
chromatic aberrations. I also know that is faster (f 4 vs f 5.8), but also lacks of A mode and is heavy...
I have seen many photos taken with these lenses, and i'm still undecided. In some pics it seems that the 100-300 is more sharp, its possibile?? I would like to know which has the best image quality because i always crop (i do nature photography). I'm not interested in using them with a Teleconverter, because i have a 400mm prime lens.
The proposals are 120 $ for the K 300 and 100 $ for the 100-300, both includes shipping cost.
Thank you for the help!!!
04-10-2016, 12:57 PM   #2
If you already have a 400mm prime, I think you'd appreciate the flexibility of a zoom. If you're shooting on digital, perhaps consider the DA L 55-300mm as well.
04-10-2016, 01:01 PM   #3
There is more than one FA 100-300 -- the silver one that goes to f/5.8 is better, and it is quite good for a consumer zoom. (It is also very light.) If you've already got a 400 prime I'd go for the lightweight AF zoom as a walkaround between those choices (it is not suited for manual focus, so if you often avoid AF, don't get it). It needs a hood though -- find a 58mm screw-on for it...
04-10-2016, 01:14 PM   #4
jatrax's Avatar
If all you are ever going to use them at is 300mm then it might be a difficult call. But adding the zoom and the AF, and the auto exposure, and the light weight? I would go with the 100-300.
04-10-2016, 02:01 PM   #5
The K300/4 is actually very light. Yes it does exhibit CA but I suspect sample variance is also broad in this matter. I have handled two, the first was really bad CA but the second, after a clean, is no where near as bad and in fact surprised me. I was going to sell it but now decided to keep in the collection (good copy?).
Perhaps the FA100-300 is the better choice? I think each lens has its strengths and weakness. As for CA in the K300/4 you should know that is almost gone by f5.6 and gone by f8 - I am not sure if the FA100-300 can match this.
Cheers
04-10-2016, 02:31 PM   #6
UncleVanya's Avatar
I had the FA 80-320 and found it inferior to the DA 55-300 if that helps any.
04-10-2016, 02:59 PM   #7
mwilky55's Avatar
I liked the FA 100-300 F4.7. If I weren't trying to control myself, I would have it again. MTC.
04-10-2016, 03:38 PM   #8
Des
Des's Avatar
My comments echo several of those above, but I've got one point to add.
I've got a 400 f5.6 prime and a 55-300 (both AF and AE). It's a good combination: the 400 for reach, the zoom for light weight and versatility.
What I miss though is speed, especially considering the 55-300, like most consumer tele zooms, needs to be stopped down to f7.1 or narrower for optimum sharpness. I expect it would be the same with the 100-300.
So a key question, I think, is how often you want to shoot at 300mm in poor light. If the answer is "usually", go for the prime. Otherwise go for the zoom, for its AF, auto-aperture, versatility and light weight. For those occasions when the light is insufficient, try a flash extender, like the cheap and light-weight Rogue Safari: https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/256288...-extender.html
04-10-2016, 04:07 PM   #9
UncleVanya's Avatar
QuoteOriginally posted by Des Quote
Good advice but if the K300 is typical the CA's will be pretty bad wide open and you may have to stop down anyway.
04-10-2016, 04:27 PM   #10
I had the F 100-300mm (f4-5.6) and it was particularly unimpressive at 300mm. As vonBaloney notes above there are two FA 100-300mm. If the one you're looking at is the one that is optically the same as the F then I would suggest it's not going to impress, specifically if the 300mm end is your priority.
The K 300mm gets slightly mixed reviews, with CA/fringing often mentioned, however if you pp from RAW fringing can usually be alleviated. Seems like most consider it to be sharp. f4 is the thing - a whole stop faster than any $100 dollar zoom and all the contemporary 300mm f5.6's. But you could consider that you've got that sort of field of view covered already with the 400mm.
I got my DAL 55-300mm for less than $150 equiv !!!! nuff said, its sharp and beats the 100-300mm hollow IMO
04-10-2016, 05:10 PM   #11
Des
Des's Avatar
I guess that is one reason why the more modern 300mm primes command such a premium.
And why trying to do telephoto on a very limited budget generally leads people back to the modern consumer zooms, particularly the Pentax 55-300.
QuoteOriginally posted by marcusBMG Quote
The DA-L is amazing value. But if even the DA-L 55-300 is out of range, maybe the Sigma 70-300 would be a better option than the previous generation xx-300 or xx-320 zooms? The Sigmas are cheap as chips, and from what I have seen, they aren't too bad.
04-10-2016, 10:26 PM   #12
gofour3's Avatar
Some may see the lack of a tripod mount on the K300/4 as a negative.
Phil.
04-11-2016, 03:52 AM   #13
Thanks for all the replies. I shoot on digital and i always do post production, the fact is that some have told me that the K 300 suffer so much from aberrations, which i'm worried that the post production may be not enough to correct CAs. Probably overdo rumors ! I shoot usually with low light but i have a KS1 that is good with high ISO values...I meant the FA 100-300 silver version (SMC Pentax-FA 100-300mm F4.7-5.8 Reviews - FA Zoom Lenses - Pentax Lens Reviews & Lens Database), i heard here in the reviews that IQ and sharpness are very comparable to the DA 55-300. I also shoot mostly in manual focus, but my real problem is figuring out which of the two has the best iq/sharpness between 300 k & fa 100-300 silver at the focal lenght of 300mm...Sorry if I did not specify, but i already have a zoom up to 200mm, so i need only focals above 200...
Thank you again
04-11-2016, 06:41 AM   #14
UncleVanya's Avatar
I wish I had both to compare. I'm afraid while I do have the DA 55-300 and an FA* 300 I don't have a K 300. The FA* crushes the DA 55-300 but that's to be expected.
04-12-2016, 03:40 AM   #15
I had the K300 some years back. Maybe it was my copy but I could not get sharp images from it. Accquired a 55-300 later and sold it away..
For what it is worth, you can get one of those cheap third party tripod mount from Internet. With a little padding, you could use it with the K300.
300mm, fa, image, k-mount, lens, pentax fa 100-300, pentax k 300 f 4, pentax lens, proposals, quality, slr lens, smc pentax
For Sale - Sold: PENTAX FA AF 100-300 mm F/4.7-5.8 Lens gsalmins Sold Items 2 02-26-2015 09:14 PM
Which to buy? FA 100-300 4.7-5.8, or 55-300 DA-L? GibbyTheMole Pentax SLR Lens Discussion 19 03-15-2011 07:15 AM
DA 55-300 or FA 100-300 4.7 - 5.8 gsalmins Pentax SLR Lens Discussion 4 01-08-2011 11:05 PM
All times are GMT -7. The time now is 08:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
