Define "good". Screw-drive traditionally seems far less prone to failure than in-lens motors, so that's a plus. With regard to speed, the body can make a lot of difference, because the in-body motor has been upgraded a few times (K-7, K-5, K-3, etc). I don't think SDM lenses have benefited from an increase in speed with newer generation bodies, because in that case, upgrading the body does not upgrade the AF motor. Maybe newer bodies have faster AF, in the sense that they have better AF sensors, algorithms etc that get it right with fewer attempts. But in that case, that should again benefit both screw-driven lenses and SDM lenses.
Some people say that lenses with shorter focus throw focus faster than those with longer focus throw. That would be the case if the rotational speed (the number of degrees per second) was constant between all lenses, which it is not. It may very well be that a lot of lenses with a long focus throw focus slower than those with a short focus throw, which could lead to that conclusion. But that's the same thing as dismissing the existence of yellow cars because you only see grey and blue ones.
