Originally posted by jatrax Thank You! I know that was a dumb question but I've got it now. I'm going to reshoot tonight with better, more even lighting and see if that makes any difference.
I'm heading to a wildflower site tomorrow at sunrise and would like to take this lens, but I won't if I'm considering sending it back. I've no problem testing in the studio but I figure once I've had it in the field it's mine.
btw, was just reading about the Circle of Confusion and came across this:
For most people, the closest comfortable viewing distance, termed the near distance for distinct vision (Ray 2000, 52), is approximately 25 cm. At this distance, a person with good vision can usually distinguish an image resolution of 5 line pairs per millimeter (lp/mm), equivalent to a CoC of 0.2 mm in the final image....
A comfortable viewing distance is also one at which the angle of view is approximately 60° (Ray 2000, 52); at a distance of 25 cm, this corresponds to about 30 cm, approximately the diagonal of an 8″×10″ image....
if the larger final image will be viewed at the normal distance of 25 cm, a smaller original-image CoC will be needed to provide acceptable sharpness.
So basically what that means: the 5(00) line pairs in your test chart correspond to the avg human eyesight for an 8x10 image viewed at 25cm.
