04-14-2016, 04:27 PM   #16
Any of those bird pictures is as good as any bird on branch pic I have ever taken at close range without glass behind the primary lens. Or better. Mostly better.
04-14-2016, 04:37 PM   #17
jatrax's Avatar
QuoteOriginally posted by pathdoc Quote
Better than any bird picture I have ever taken. Period. But then birds and I don't get along well.
04-14-2016, 05:07 PM   #18
normhead's Avatar
QuoteOriginally posted by bertwert Quote
Great results!
Wouldn't that be f/9.5 fully open instead of f/6.7?
f/4 - 1.5 stop (for the 1.7x) = f/6.7
f/6.7 - 1 stop (for the 1.4x) = f/9.5
I put the A-400 ƒ5.6 on the camera with the 1.7 on, it said 9.5. You win.
04-14-2016, 05:09 PM   #19
bertwert's Avatar
The A-400 talked?
Amazing
04-14-2016, 05:14 PM   #20
normhead's Avatar
The A-400 talked?
Amazing
It talks to the camera screen. The camera screen communicates with me... it makes little squiggly lines that I understand.
04-14-2016, 07:39 PM   #21
normhead, those are great pictures, especially the first one with the male house finch. However you connected the components, it worked well. A single 3x TC might have worked better, if it were equivalent in optical quality to your two TCs. Used 2x and 3x ones seem to be by far the most commonly available. But I don't see any reason to knock what you are doing.
04-15-2016, 04:13 AM   #22
QuoteOriginally posted by goatsNdonkey Quote
If. That's potentially a very big if. I have a 3X teleconverter back from the original K mount days. The results it gives are godawful.
04-15-2016, 05:55 AM   #23
normhead's Avatar
That's what I was going to say, the reason I never owned a converter before the F 1.7 was I'd never seen work from one I could appreciate. The ones from the 60s and 70s are terrible, and a lot of the attitudes towards them are hold overs from that period.
04-15-2016, 06:22 AM   #24
I just have a 2x TC, but years ago in my screw mount days I also owned a 3x. I didn't use it, not because of a quality problem, but mainly because I didn't want that much light loss. I'd like to snag a decent 1.4x sometime, and if I did I'd probably never use the 2x. I don't know if there were any particularly high quality 3x TCs. Perhaps the lens makers who might have made them would have rather people just buy a longer lens from them.
Actually, my suggestion that using one 3x would be magnification-wise like using your 1.4+1.7 combo was the result of fuzzy math. A single TC that would give the same magnification would actually need to be approx. 2.4x. I guess a high quality 2x TC would get you close, but why bother when you're getting such great results.
04-15-2016, 06:33 AM   #25
normhead's Avatar
That's what I was thinking. I was kind of hoping to get something comparable to the Canon 2x, but this in my mind is better. More options. I can select 1.4, 1.7 or 2.4 depending on circumstances, that's almost like having a zoom.
04-15-2016, 06:56 AM - 1 Like   #26
. . . . in my mind is better. More options. I can select 1.4, 1.7 or 2.4 depending on circumstances . . . .
Like a lens with a 3-speed transmission!
04-15-2016, 07:12 AM   #27
12345's Avatar
That is funny!
04-15-2016, 07:54 AM   #28
normhead's Avatar
Don't forget the original FL. Four on the floor. Well, if you leave you camera bag on the floor, it's four on the floor.
Since the 60-250 theoretically has an infinite number of focal lengths, You have infinity times 4 number of FL settings.
04-15-2016, 09:03 AM   #29
bertwert's Avatar
Uhh... ok then...
04-15-2016, 10:13 AM   #30
normhead's Avatar
Uhh... ok then...
You don't sound convinced, say that with some enthusiasm.
600mm, af, da 1.4 tc, da*200, f1.7 af adapter, focus, hd da, images, k-mount, lens, norm, pentax lens, results, slr lens, tc and f1.7, tcs
For Sale - Sold: DA 60-250mm zoom with extra tripod mount, HD DA 1.4 TC dshombert Sold Items 4 08-17-2015 05:19 AM
Macro Failure to capture With K-x and stacked lenses smf Photographic Technique 21 01-08-2015 01:25 PM
K3 with Stacked 1.4 and F1.7X Rear Converters DDoram Pentax K-3 & K-3 II 14 06-26-2014 12:37 AM
For Sale - Sold: Da 15 ltd, da 70 ltd, dfa 100 wr, da* 60-250, f 1.7x af adapter dltorre Sold Items 11 06-14-2014 07:38 AM
For Sale - Sold: DA* 60-250, DA 35 Macro Ltd, DA 18-55 WR, Kenko 1.5X TC with SDM contacts buzzvic Sold Items 10 09-08-2012 07:35 PM
All times are GMT -7. The time now is 01:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
