As I have recently accepted delivery of my new 'HD Pentax D-FA* 70-200mm f2.8 ED DC AW' lens, I thought that I would write some first impressions from the first week with the lens, and discuss some preliminary findings comparing it against the 'SMC Pentax FA* 80-200mm f2.8 ED [IF]' and the 'SMC Pentax DA* 60-250mm f4 ED [IF] SDM'. With that mouthful out of the way, lets begin.
Build Quality:
As covered in my previous thread comparing the FA* 80-200mm against the DA* 60-250mm (
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/315001-buil...-80-200-a.html), I believe the construction of each of those lenses are equal, though decisively different from each other. The D-FA* 70-200mm lens on the other hand, is on a completely different level. The build quality of the new lens is virtually impeccable, with the single point of fault being the tripod foot design.
Though the foot itself is sturdy and looks to be fit for professional use (unlike those on the FA* & DA*), it does sit a little to close to the handgrip of the camera. With the foot rotated 90 degrees to the right, the camera is unusable. Fortunately, Ricoh has finally figured out how to design tripod foot's for it's lenses. The balance when place with or without camera attached does not effect the balance of the foot, and the foot is large enough to be used as a carry handle. The DA* tripod foot, is in my opinion adequate but not perfect, and the foot of the FA* is inadequate due to its size and placement, though on a tripod all foot works reliably.
Aside from that, the lens is immaculate in its design, with Ricoh opting to go with aluminium for the overall design of the lens, unlike the polycarbonate shells of the DA* 60-250. The zoom and focus rings deserve mention also. When it comes to manual focusing, the lens does (in my sample), make a slight noise, but is otherwise incredibly smooth as all high end Pentax telephotos are, the degree of travel is approximately 110 degrees (vs the FA*'s 110 degrees & the DA* 70 degrees). The room ring is also incredibly smooth and suffers no zoom creep (Unlike the DA* 60-250mm), and is weighted well. I have yet to decide whether I will miss the 'Power Zoom' of the FA*, but I suspect that I will, for I find it a fun and useful addition to what is obviously a pro level zoom.
When it comes to weight, the D-FA* and the FA* are within close margins, though the improved design of the D-FA* does aid in it's use handheld. The DA* on the other hand is a lens which one can use all day without fatigue. It is simply in another weight category in comparison to the other two behemoths. Handhold all the lenses can be done, though both of the 2.8 zooms will require much better technique in order to handle at the same level as the DA* 60-250.
Now, the last thing worth mention is that the D-FA* is a monster of a lens, both in weight and in volume. The photo below proves it, it is simply gigantic, even in comparison to the already huge FA* lens. With the attached hood, the lens is almost as good at gaining attention as that of the silver FA*, though not quite as many questions have been asked about it thus far.
AF:
The AF comparison between the three lenses is a simple one. The D-FA* is superior in all ways to the FA* and DA*. That said, there are some things to quickly cover. Though the FA* lens is screw driven and the DA* is powered by SDM, if choosing between these two lenses in regards to AF, I would always chose the FA* lens. It is simply a day and night difference between the two lenses, and paired with a modern body (K-3 up), there is simply no good reason to go with the DA* lens, as long as the noise of the FA* is of no concern.
Between the FA* and the D-FA*, the AF speed is much more comparable. The difference between the two lenses can be summed up in three points. First, the AF on the D-FA* does not hesitate, and when it focuses, there are no micro adjustments attempted by the camera, whereas depending on lighting and subject matter, the body will attempt micro adjustments with the FA*, taking up valuable time. Secondly, the DC motor in the D-FA* lens (and this is only a first impression, YMMV) seems to be much more confident in AF-C mode, and seems to stick with the subject much more than the FA* lens, though it is no slouch in this department (in Pentax terms). Third but not least, the AF limiter is invaluable, and can significantly speed up AF acquisition, shortening the focusing throw of the lens.
That concludes my short overview of the Build Quality and AF of the new D-FA* lens, I hope you enjoyed the read! (Ps, sorry about the horrible pictures, but does anyone know how to embed the photos directly into the post?)
