02-11-2007, 02:37 PM   #1
Ricoh lens pin?
I just won a 50mm 1.4 ricoh lens on evilbay. Does anyone have a picture of this pin that needs to be plucked out so it wont get stuck on my body? Anyone ever use this lens? Thanks.
02-11-2007, 09:10 PM   #2
clm
I haven't used that lens, but I have used a Ricoh 28mm and a 2X macro teleconverter on a Pentax AF camera without it getting stuck. The pin was smaller than the electric contacts on a Pentax lens. I think the stuck lens problem is limited to second-rate third party lenses. Brands Keh.com refers to as "miscellaneous". If it's not a program lens, it will be the same as a Pentax-M lens.
02-12-2007, 03:13 AM   #3
I can't show you the pin, but I can show you the end result. The image below is a Tokina 24mm. At about the 7 OClock position you can see a covered pin hole just to the left of a small phillips head screw. This is where the offending pin was. I just gently moved it inside the lens body and sealed it with a dab of epoxy, sanded smooth.
02-12-2007, 04:37 PM   #4
thanks for the info, I'll check it out when I recieve it.
k-mount, lens, pentax lens, ricoh, ricoh lens, slr lens
Anyone bother to seal Ricoh pin holes? ratm4484 Troubleshooting and Beginner Help 6 04-08-2011 12:00 PM
Does the Vivitar 19mm f3.8 have the infamous Ricoh pin? nandystam Pentax SLR Lens Discussion 14 01-03-2011 06:44 AM
Chinar Lens Sticks But No Ricoh Pin? magkelly Pentax SLR Lens Discussion 7 11-29-2010 11:05 PM
All Right...I did it....Ricoh Pin Lens is STUCK! Raylonn Pentax SLR Lens Discussion 31 10-16-2010 07:38 AM
Removing Ricoh Pin - alternatives aseno Pentax SLR Lens Discussion 22 05-22-2010 03:16 AM
All times are GMT -7. The time now is 07:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
