So far my personal experiences got me to pick on this lens as I went once trying to do something/anything with my Sigma 28-300 (really decent zoom range, otherwise pretty much useless in low light conditions and quite prone to CA but it was cheap) and as I spent the hour and a half shooting whatever I thought might be a good moment to capture, ended up with 95% of all shots being within the 28-55mm range. Only a few went further, say max 70mm. Next time I did the same with the standard DAL kit lens and again, most of the shots were between 20-22mm up to the maximum 55, mostly ending at 48 or 50mm. So, my conclusion is that the 17-50mm range should be just fine for the purpose. Outside (daylight or static objects, portraits, landscape, architecture etc) is a completely different story, got it covered with multiple zoom lenses and one Tamron 90mm Macro lens.
My main problem is that I want to catch a fast movement at low light without getting a smudged silhouette and at this time, I can only do a capture of a moment between two movements without getting it all blurred out
Ok, some of those images do turn out well, but most of it is just a waste of time and ... well... rubbish...
I would prefer to have the zoom option as the girls (ballet) do run around, come and go and I just never know if there's a moment when the distance from me will be at four or ten meters, sometimes I want to catch a detail and sometimes the whole scene, so the zoom does make sense... At least I think so...
I know my K-S1 is a good camera and I definitely don't blame it for my incompetence
It's fast enough so I do use RAW (no lagging to write data to the memory card) and that's all ok, often do some post processing to iron out minor imperfections, but there's the saying "sh*t-in, sh*t-out", so, I can't make miracles from bad grainy and/or messy shots... Thus the topic...
