Originally posted by KTschappat As I get closer to purchasing the K-1 and a portrait lens (going to the bank after I post this to put some cash into the account I will use at B&H), I am becoming afraid I may be making the wrong purchase with the 77mm. As much respect I have for the lens, I fear I may be buying the best lens I won't use. When I started portraits using my Super Program, I bought the 135 2.8 to get the look I was after. I own the 50 1.4, but rarely used it then, and I rarely use it now when I take portraits. It is my walk around lens, nothing more. I use my 18 - 55 for the wide angle, and the 40 - 80 when I go into the studio way more. My fear is, I will buy one of the best lenses in the world, and use it for 5% of my portrait images like I do with the 50mm. It is my opinion that some of the opinions I have been reading here have been from experience gained from using the 77 with a crop sensor. If I was using a crop sensor still, the 77 might be long enough for me, but I fear the 77 will be like my 50 is right now. I need sharp, and auto focus, I just fear the 77 will really be too short. I am buying this camera in another day or two. Argh!!!
DO NOT buy what you don't know if you need.
If 135 was your go to focal length then you should not jump on an FA* 85 or FA 77 until you use them. The hedge bet would be the DFA 70-200 - it ticks all the boxes and has a flexible range. Other options, the older FA* 80-200, the FA* 200 or DA* 200 (but those could be a bit long), the FA 135, the DFA 100.
Personally I would rent a 70-200 even if you don't plan to buy it - to get a feel for the focal length. In 135mm, the problem is mainly that this focal length is underrepresented by Pentax in fast aperture FF lenses available to buy other than the DFA 70-200.
