Originally posted by Cambo a 100-400 APSC would be significantly smaller and lighter than the 150-400 full frame...
Cheers,
Cameron
This is a source of endless debate but the data seems to suggest that telephoto lenses don't really gain a lot of benefit in size from the APSC vs. Full Frame at the same f/stops. I'm not sure that a constant f/4 zoom from 100-400 would be that small. As an example look at the Panasonic m4/3 100-300 f/4-5.6 that lens is slightly larger and heavier than the Pentax 55-300 f/4-5.8 made for APSC (although reports are pretty good as far as FF goes). it is my understanding that the main benefits come with the smaller focal lengths. For another comparison point the Olympus 300mm f/4 weighs 1300g while the DA* 300 Pentax weighs only 1070g.
Remember that m4/3 is about a 1.33 crop factor relative to APSC and a 2x crop to FF. If any benefit was to be had you would see it in m4/3 I would think.
What likely makes the 150-450 heavy is the excellent glass used in it.
