Originally posted by Nicolas06 For many photos, it wouldn't make any visible difference.
In general (flat images), you wouldn't see a significant difference between apsc and ff formats, ok.
For the case of the 70-200 and 50-135, that's completely untrue: both lenses are primarily designed and used for portraits because of the focal length range, distance to subject and convenience and changing the field of view (include or exclude more or less of the background to frame the environment of the subject). For other applications such as air shows, sports and animals, 50-135 is mostly too short, 60-250 , 200mm or 300mm are preferred. Back to portraiture, between the 70-200 2.8 on FF and the 50-135 2.8, the difference in image rendering / bokeh is as visible as the increase in weight and price, due to the size of the diaphragm opening is twice as large on the 70-200 vs 50-135. Shooting 170mm f2.8 on FF delivers similar bokeh as 85 f1.4@f1.4, about 113mm @f1.8.
Originally posted by Nicolas06 Going the 70-200 + FF route make sense if you need to deal with the noise, mostly.
Not at all. While you can use a 70-200 f2.8 on a K3 to get in the 100-300 range for sports, the use of 70-200 on FF has nothing to do with noise.
---------- Post added 16-05-16 at 22:13 ----------
Originally posted by Nicolas06 And my bet is even with all the difference between K3 + FA77 & F135 on one side and K1 + 70-200 on the other side,
The F135 is meant to be used on FF, this is for the same use of 90mm on K3: head the shoulders portraits.
