robthebloke - AFC or AFS (k5 doesn't have a AFA mode) yield the same results. Slowly rotating back and forth never locking a target. Regardless of bright/dark/contrast subject, single or all focus points.
K57xr - when I turn the camera on, it says "DEBUG MODE" in the top left. If I hit menu, I can access "test mode" which contains capture/system test, af test, strings disp test, icon test, and debug mode disable. Is there a deeper debug mode I need to access?
I probably should have clarified, this is the part I'm at/stuck on.
"Use the pad to go to the line
LENS EEPROM SAVE"
Is that displayed on the camera menu or will I find it in pktether, or on the sd card?
Thanks y'all again.
EDIT - using the link that led to dropbox folders has helped! New menu opened in camera!
