Unfortunately, years of neglect by Ricoh's predecessors have put us between a rock and a hard place when it comes to full frame prime lenses.
a) If you want weather sealed primes, your only choices are the DFA 100mm WR macro, DA* 200mm and DA*300mm. So you are fine on the longer end of things, not on the wide end.
b) If you want a prime with silent focusing (in lens motor), the only choices are also above (minus the 100mm WR which is screw driven). The noise doesn't bother me as much as the fact that there is no quick shift.
C) If you want to buy something new and avoid the risks inherent in buying used, the widest prime you can get is the 31mm. Although a great lens, is missing the features I mention above. And 31mm is not all that wide.
d) The limiteds, while render they like no other, are not as corrected for things like CA and purple fringing. Some think that is part of their charm. Some don't like it. It is subjective of course.
Fortunately, there is good news
The 15-30mm, 24-70, 70-200 and 150-450 are superb lenses that can go toe to toe with any other zoom lens out there.
