Originally posted by Na Horuk Is the DFA 100mm better on K-5 than on the K-3? Because the K-5 has same pixel density as K-1.
Well, yes, and no. The K-3 has a resolution corresponding to a 54 megapixel full frame sensor. And this lens' strength clearly isn't on the resolution side, which you can see if you compare the MTF for full frame, measured at 20 cycles (line pairs)/mm with those for APS-C, measured at 1,5x the frequency - 30 cycles/mm.
Going through the various macro lens reviews at Objektivtest.se I can find several newer lenses that performs better with APS-C. For instance Tamron SP 90mm f/2.8 Di VC USD (
TEST: Tamron SP 90 mm f/2,8 Di VC USD Macro) and Canon EF 100mm f/2.8 L IS Macro (
TEST: Canon EF 100 mm f/2,8 L IS USM Macro).
So I don't find it that peculiar that the Pentax D-FA 100mm f/2.8 Macro WR reveals its weakness more on a K-3 than on a K-5. It's definitely a sharp lens but not among the sharpest today.
Also check out their review of the Tokina AT-X 100mm f/2.8 Macro. If you look at the MTF it performs more or less on the same level as the Pentax 100/2.8 Macro. Which is logical since they have a similar optical construction. Also the old, classical Tamron SP 90mm/2.8 Macro doesn't quite match the performance of the newer version. The difference is more obvious with APS-C than full frame.
TEST: Tamron SP AF 90 mm f/2,8 Di Macro
Cheers!
Alex
