Originally posted by sergysergy correct, M42 lens with an adapter (which looks like the K mount one)
Well that'll work.
As soon as it arrives I'll confirm. Thanks.
---------- Post added 05-20-16 at 06:24 PM ----------
Originally posted by Not a Number Looks like you lucked out and it has a M42 to K-mount adapter. With even more luck it may even be a genuine Pentax adapter. It should unscrew unless it has been thread-locked or glued on. Try using a K-mount rear cap as a wrench if it is a little tight but don't use excessive force.
If it is a genuine Pentax it should be labeled Asahi Pentax or Pentax and Japan or Philippines.
Well now I'm especially anxious to have a look at it. Should be here soon so I'll follow up. Thanks for the insights. I already have one of these lenses but I figured this one looked intriguing plus I gather some vintages are better than others so why not nab it. Thanks again. Cheers.
