Originally posted by BeginningwithN UncleVanya earlier in the thread (like 3 years ago earlier
) you mentioned you had instructions to use the K100d super? I have tried quite a few methods to access the debug menu with no luck so far. I was wondering and hoping you might share that information? I would greatly appreciate it as I purchased this camera specifically to convert my 16-50. Thanks in advance
Have you been able to get into the menu at all? If not review the instructions:
[DEBUG_MODE EN]
[OPEN_DEBUG_MENU]
Save the txt file, then change the name to MODSET.459. Confirm you want to change the extension when prompted.
Now move this file onto the root directory of your SD card (I used an old 128mb card for this kind of stuff).
Place the card in your camera. While pressing the menu button, and with the card door open, turn on the camera. The top deck LCD will flick on then off. Turn the camer off, close the card door , and turn it on again.
You are now in debug mode. Mostly looks the same. Press menu, right arrow over to the set up menu. A the bottom of the set up menu you will now see options that weren't there before. One of them is AF TEST. Select it and right arrow. Don't mess with the AF AREA, arrow down to the Fous Cirrection and adjust. To fix back focus, you want to slide right, positive. Vice versa for front focus, slider to the left. I did 50 to start and ended up at+80.
To get out of the debug mode, turn off the camera, take out the SD card. Replace the contents of the card with the following:
[DEBUG_MODE DIS]
[CLOSE_DEBUG_MENU]
Put the card with the new command script back in the camera and with the card door open, hold menu button down and turn on camera. It will flash the LCD like before and go off.
You're done! Replace card with normal one and happy shooting with your finely tuned camera!
Originally posted at 3:24PM, 6 July 2013 CST (permalink)
_rudeboy_ edited this topic 68 months ago.
(Taken from:
K100d Super debug menu | Pentax K100D Super | Flickr)
Then once the debug menu pops up - hit menu - this takes you to menu 2, then follow these directions:
Here is what seems to work best:
1A: Put an SD card (prefer blank but any with space will work) in the slot
1B: DO NOT CLOSE THE SD CARD DOOR (This may vary with method try both ways)
2: Turn on camera.
3: You now enter the debug mode
4: Press MENU once
5: Close the SD card slot door.
6: Select LENS EEPROM R/W and PRESS OK
7: Select LENS EEPROM STORE
8: Camera will say, "WAIT" and then returns to step 3.
9: Power down check SD card to ensure a file called LENSEEP.LNS file was written.
10: MAKE A BACKUP - I tend to use lens name & serial number
THIS IS LENS COPY SPECIFIC - ONLY YOUR FILE WORKS WITH YOUR LENS!
11: Use an editor to make the changes listed in the forum threads to convert to screwdrive.
12: Back to Step 1 until you reach STEP 7. Then...
13: Select LENS EEPROM R/W
14: Select LENS EEPROM LOAD
Cross your fingers...
Save a copy before and after one named LensID_SerialNum_LENSEEP_BadSDM.LNS and one named ..._ScrewDrive.LNS - this allows you to convert back should you get it repaired.
Then change the code "C0" by "80" in the column 03 for every instance.
When you are done repeat steps 1
