01-31-2023, 12:16 AM   #331
Thank you very much, lens arrives today, and I am very tempted to try it. 50-135 mm would nicely complement 20-40, so I could find another home for my travel 18-135.
Just another question, can the conversion to screw drive be done with any of the following: K50, K3iii or KP?
If not, I will need somebody's help, which is another big - for the lens.
01-31-2023, 06:17 AM   #332
UncleVanya's Avatar
QuoteOriginally posted by Fila Quote
I own both of those combinations. I kept all three lenses. The 18-135 is more convenient when traveling - the 20-40 + 50-135 is more special.
No, the k-50 and KP bodies won’t be able to convert the lens. The debug mode can be entered on the k-50 and KP but the lens rom read and write functions don’t work. I’m unclear if the k3iii has a debug mode that is known, but no one has demonstrated that it can covert sdm lenses so far. The k3iii uses a different processor and operating system which may have very different underlying mechanisms.
01-31-2023, 08:04 AM   #333
deus ursus's Avatar
I converted a lens with my K-5IIs ...
01-31-2023, 08:51 AM   #334
Mikesul's Avatar
Can you give more details about how you used the K-5IIs? thanks
01-31-2023, 09:02 AM   #335
deus ursus's Avatar
It's a while ago, so.I'm not quite sure, but I believe I followed the steps in the OP.
01-31-2023, 05:13 PM   #336
Hi. I'm not 100% sure which lens+body combo you and Fila are referring to but I can confirm that I successfully converted my 50-135 to screw drive using my K-5 body following the instructions here.
01-31-2023, 06:07 PM - 1 Like   #337
UncleVanya's Avatar
QuoteOriginally posted by deus ursus Quote
QuoteOriginally posted by chrisd015 Quote
My reply earlier said "K-5" when I meant "K-50" it was a phone typo. I was replying to the person asking if their K-50, K3iii, KP could convert the lens. Yes the K-5 series appears to work. I don't use it myself so I don't know the details well. I know PKTETHER is one option but I think the SD Card trick to enter DEBUG works. Once in Debug the basics are the same. You take a copy of the file, edit it outside the camera (or on camera if you dare), save a copy and update the lens. Nothing complex. I can add color to this if needed.
02-01-2023, 12:21 AM   #338
deus ursus's Avatar
Ah! Those dreaded smartphone keyboards!
02-01-2023, 06:20 AM - 1 Like   #339
UncleVanya's Avatar
Lol. I shouldn’t complain. I’ve turned autocorrect off and found it was worse in many ways. I should proofread more.
02-03-2023, 09:55 AM   #340
Something odd is happening; I have converted a 16-50 with a K5IIs; I had 16 C0 values only on the 3rd row; changed them to 80. Now at 16mm, 50 mm and somewhere between my lens cannot focus at all because it is seen as a manual lens. Any ideas, please?
02-03-2023, 11:57 AM   #341
Asahiflex's Avatar
QuoteOriginally posted by rzvnz Quote
Did you make a backup of the original file? You could always do it again in case youe missed something (and even convert it back to SDM if you wish).
02-03-2023, 12:17 PM   #342
I have made a backup; I restored the original file and the lens is viewed correctly at all focal lengths, but the SDM is not working.
02-03-2023, 02:19 PM   #343
Instead of editing the file you can use one of the 16-50 profiles available on dropbox. I tried this on my k5iis and it worked.
02-03-2023, 07:53 PM   #344
QuoteOriginally posted by pimpim Quote
Can you point me to the dropbox link, please?
02-03-2023, 09:11 PM - 1 Like   #345
I found the issue: at the left of the first column there are also a few C0 values that I accidentally modified; all is working normal now.
anomalies, camera, card, change, drive, file, files, firmware, hack, issues, k-mount, lens, mode, pentax, pentax lens, pktether, pm, post, power, profile, rom, screw, sd, sdm, slr lens, thanks, thread
For Sale: SDM to Screwdrive Conversions UncleVanya Photographic Equipment for Sale 336 03-24-2024 07:46 PM
For Sale - Sold: SMC Pentax-DA* 16-50mm F2.8 ED AL [IF] SDM converted to screwdrive transam879 Sold Items 4 04-08-2015 09:22 AM
SDM failure in body without default to screwdrive? kxr4trids Pentax DSLR Discussion 8 08-14-2010 06:41 AM
K20D defaulting to screwdrive focus instead of SDM shemj Pentax DSLR Discussion 15 01-26-2010 04:22 PM
[Wanted] tutorial to convert/edit video from K-7 to netuser Video Recording and Processing 5 09-14-2009 04:01 PM
All times are GMT -7. The time now is 04:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
