05-26-2016, 07:51 AM   #31
luftfluss's Avatar
Every now and then I nail one with the A-400 and the 1.4. but, it's been a while. With the 1.4 it's still plenty sharp enough. With the 1.7 I think you are testing the resolving power of the lens.
Oh, no doubt I am doing hell to the A400 with the old 2x TC But it's fun! And it's giving me a chance to evaluate the usefulness of the combo in terms of handling and focal length, in case I want to buy the Rear Converter-A 2x-L, which is a match for the lens.
I once had the Rear Converter-A 1.4x-S and had good success with it on a 300mm Tak, but I wasn't comfortable using it with the A400. I probably should have spent more time learning the combo before selling the TC.
05-26-2016, 04:28 PM   #32
Norm, is that a variety of flycatcher in your post #25? The head shape says flycatcher to me. King birds and Phoebes are my friends.
I hope to sometime have a TC in the 1.4-1.7 range, and if I had one of them, I would probably use a TC much more often, mainly since there would be less light loss. So far I have only owned 2Xs and for a time a 3X.
I have something else in my kit that is sort of like using a 1.5X TC -- putting a lens on my cropped sensor K110D dslr! It gives an apparent big boost to focal length compared to using the same lens on a full-frame film body.
05-26-2016, 06:05 PM   #33
normhead's Avatar
That's a Pine Siskin, a whole flock of them, about 400 birds stayed at my place for about a month waiting for the weather to break further north.
06-04-2016, 02:30 AM   #34
I still get the impression that if you need 600mm+ a 150-600 provide more than a DA*200 or DA*300 would do with all the TC you'll want. You get f/6.3 instead of f/8-f/9 equiv.,n you get better AF and you still have zooming capabilities that the prime + TC will not have.
Funily if you read people that brought a K1, a body with a bit less magnification than best APSC, people are more satisfied. Because AF work better, because you get 1.22 stop in theory from sensor size, more like 2 stops in practice of noise control meaning a 150-500 act more like a 100-350 f/2.5-3.2 lens on a K3 and that something that can't be brought. A 150-600 if we could have one on K mount on a a recent FF would act like a 100-400 f/2.5-3.2 on a K3.
You combine the low light capability of the DA*200 without TC of normhead but with more reach and details than a DA*300 all with zooming capabilities.
Hopefully K3 successor will get back the noise/iso difference to 1.22 stop like the theory says so a 150-600 on FF will be equivalent "only" to a 100-400 f/3.2-4 on APSC, but nothing is sure, manufacturers may want to keep big difference in performance to bring people to buy the more expensive FFs.
The thing is a DA*200 may very well outresolve a K3-II 24MP sensor in the center stopped down to f/4 or f/5.6, but it may not outresolve a 216MP sensor that would allow to get 24MP worth of detail at 600mm cropped. Sure a DFA100 macro might be able to handle better a 3 time increase in focal length, but the issue is always the same. Longer focal length need bigger/heavier lenses to resolve more details and so the longer focal length you buy, the more you have the spend or the less margin you get and so the less usefull a TC will be.
06-11-2016, 01:51 PM   #35
normhead's Avatar
If you need 600 plus, then the Sigma 500 ƒ4.5 with the 1.4 is probably the way to go. Or maybe an A*400 ƒ2.8 with the F 1.7x AF adapter. When I want 600 plus I go with the A-400 and 1.7 But that's 9.3 and 680 and a very crippled AF system. At no point does a 150-600 lens that is ƒ5 at 150mm enter my mindset.
The Pentax 150-450 with the 1.4 is really the only option I'd consider in a zoom. That's 680mm at ƒ8, So I have an ideal solution for getting over 600mm and a not so ideal but functional solution, none of which involve 150-600mm lenses. ƒ6.3 is just too slow. Many of the shooters I know shooting Nikon and Canon gear shoot 600mm ƒ4.
06-11-2016, 03:19 PM   #36
How about a 300/2,8? With the appropriate ammount of TCs you get decent apertures:
300x1,4 = 420mm f/4
300x1,7 = 510mm f/4,8
300x2,0 = 600mm f/5,6
300x1,4x1,7 = 714mm f/6,7
300x1,4x2,0 = 840mm f/8
300x1,7x2,0 = 1020mm f/9,6
I'm glad I went for a 300/2,8 in stead of a 500/4,5 even if the last one have a slightly larger aperture diameter (111 vs 107 mm).
I have have a plan about taking comparable photos with this lens and various combinations of TCs (1,4 and 2,0), but I haven't taken those shots yet.
06-11-2016, 04:24 PM   #37
normhead's Avatar
QuoteOriginally posted by Simen1 Quote
300x1,4 = 420mm f/4
I'm glad I went for a 300 ƒ2.8 in stead of a 500/4,5 even if the last one have a slightly larger aperture diameter (111 vs 107 mm).
I did consider a 300 2.8, and that in many ways is the optimum, but, the 200 2.8 is so much more portable, and affordable.
02-03-2019, 09:25 PM   #38
swanlefitte's Avatar
Upping the geek level a bit now.
A lens will perform better on a high resolution sensor but will fall of from the best that sensor can perform.
It seems that doubling from 2k to 4k loses much less than doubling from 4k to 8k in a log function. And different magnification amplifies this. So the cropping of a photo at 8k by 1.4 will much more effect than 2k by 1.4.
I have nothing but assumption for the tc effect. If it's degradation of the image is linear or simply a different log function then there will be a resolution for each lens + tc on equal quality sensors of different pixel density where a tc is better than crop or worse. This suggests that the higher pixels the more the tc is an advantage.
Of course I could find nothing about this. I base this on the findings of this article.
Lens Rentals | Blog
If this is correct thinking then a crop mode + lens picture cropped on the k1 will perform more favorable to a crop mode +lens + tc.
And a lens + k1 photo cropped will perform less favorable to a lens + tc + k1.
04-21-2020, 12:02 PM - 1 Like   #39
normhead's Avatar
My first series of images went as follows... taken at about 40 feet, with not a lot of detail in the test subject.
DA*200
DA*200 plus 1.4
DA*200 plus 1.7
DA*200 by itself enlarged to the same size as the DA*200 2.8 plus 1.7x AF Adapter
04-21-2020, 12:21 PM   #40
newmikey's Avatar
One consideration I'm always missing in these discussions is the (positive) impact of a TC on multi-pattern or center-weighted metering: rather than metering a large image out of which only a crop is shown (such that the metering may have been impacted by areas outside the crop), the metering evaluates solely the area of interest, resulting in slightly better exposures which will no doubt benefit overall contrast as well as microcontrast.
To add to that, a lot of people who would have no issue adding a piece of "protective" flat glass in front of the lens suddenly seem to develop issues when a carefully crafted optic is added behind the lens...
04-21-2020, 03:41 PM   #41
DA*200
DA*200 plus 1.4
DA*200 plus 1.7
this is a good showing with decisive results. It should be noted these are on a 24mp aps-c sensor. I am pretty sure that will make a difference also.
It would be interesting to see the k3 and 200mm vs the k1 and 200 1.4x tc combo. my guess is not significant but perhaps the k1 wins?
Also would be interesting to see the k5 vs k3 enlargements vs regular but so many combinations it wouldn't be worth it.
04-22-2020, 06:02 AM   #42
normhead's Avatar
QuoteOriginally posted by swanlefitte Quote
I have to be really inspired before I take these things on. They can be a lot of work.
And I really have to emphasize, if I'd been close enough that the DA*200 could resolve the print crisply, there would have been no difference. And if I'd been so far away that none of the lens plus TC combos cold resolve the small print there would have been no difference. The difference is confined to a zone where the original lens starts to lose detail and ends when none can resolve the detail. It's probably much easier to show that the is make no difference . This test took some tweaking and experimentation.
At 20 meters instead of 40 I could probably have shown a series of test showing there was no new detail added.
04-22-2020, 01:54 PM   #43
I know the effort it takes. I know iI am not the only one to appreciate it.
Your last post is like a tc. It adds information on the other post.
conditions, da*200, detail, dof, image, images, k-mount, pentax lens, res, resolution, series, slr lens, target, tc, tcs
Idiot doesn't Know the Difference Between a Tripod and a Minigun Winder General Talk 23 11-21-2015 08:28 AM
on my old *ist DS photo preview doesn't work any more antoniomontag Troubleshooting and Beginner Help 5 01-13-2015 11:02 PM
Nature Who doesn't love a pelican slowpez Post Your Photos! 7 12-26-2014 02:24 PM
Pentax-F 50/1.7 doesn't show as A when using A-type teleconverter asharpe Pentax SLR Lens Discussion 8 10-31-2014 02:52 AM
Error for-sale ad doesn't show price Aegon Site Suggestions and Help 4 04-29-2011 07:43 AM
All times are GMT -7. The time now is 03:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
