May not mean anything:
K-7 and PENTAX Soft Focus Lenses | Ricoh Imaging Support
Q: Can PENTAX soft focus lenses be used with the K-7?
A: Yes. The PENTAX 85mm f/2.8 FA or F series and 28mm f/2.8 FA series Soft Focus lenses can be used automatically, or with manual aperture control. If using automatically, Aperture value (Av) will be automatically selected in the following modes: P Sv Tv Av TAv If setting the aperture manually, then "Using Aperture Ring" must be set to "PERMITTED" in Custom Settings .
The 2002 SMC Pentax FA interchangeable lens operating manual in the built-in flash compatibility table (checking vignetting) lists the 28mm and 85mm soft focus lenses as compatible on the Z/PZ, MZ and MZ-S series film cameras. I believe these bodies had analog TTL for flash so at least that should work with these lenses.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0ahUKEw...5EsUDg&cad=rja
