06-02-2016, 05:10 AM   #1
Question for the A*135mm 1.8 owners
The legendary lens is listed on ebay, but somethings seems to be odd
NO Reserve Pentax Pentax A SMC 135mm F 1 8 Green Star MF Lens PK Mount | eBay
Is it normal to see so much CA in this lens? I assume the test shots sown are wide open.
I would greatly appreciate learned views on this matter.
06-02-2016, 06:00 AM   #2
npc
Yes, looks normal to me (as far as I can tell compared to mine). PF generally is similar to what you get from all the other fast pentax film era lenses ..
06-02-2016, 01:45 PM   #3
Yes, from my experience with A* 85, the PF looks very similar.
It is quite strange indeed, that even the lenses with the same optical formula are more PF prone in A-series, than others. E.g. K 50/1.2 does not have PF, but A 50/1.2 does. FA 20/2.8 does not have PF (almost), but A 20/2.8 does. Probably there are others. An exception is A* 200/2.8 that has less PF than its sibling K 200/2.5.
06-02-2016, 03:29 PM   #4
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Wild Mark Quote
Either way, don't become too concerned it's a quick fix in todays modern PP software.
06-02-2016, 04:54 PM   #5
thanks guys - I'm in the market for this legend, but, not at silly prices. Perhaps I am not realistic in my thinking - we will see.
06-04-2016, 07:08 PM   #6
I've decided to not bid on this item. It is the second time in as many weeks it have been offered. The first time it was bid up by someone with few ebay transactions and their limited record was solely with the seller. This appears to be happening again, which tells me there is a vendor bid going on. NOT INTERESTED in such dodgy bidding.
06-07-2016, 01:19 AM   #7
hoanpham's Avatar
I bought a Zeiss instead.
ebay, k-mount, lens, pentax, pentax lens, slr lens
Question for owners of Beck 135mm f 2.8 (or anybody else) Roypercy Pentax SLR Lens Discussion 5 08-21-2020 05:07 AM
A question for owners of the Da*200 everydaylife Pentax SLR Lens Discussion 7 03-19-2013 10:33 PM
A question for K7 owners dafiryde Pentax DSLR Discussion 26 09-05-2009 02:52 AM
Question for SMC Auto F 1.7x owners? joeyc Pentax Camera and Field Accessories 4 07-14-2009 06:59 AM
Question for the K200D owners jgredline Pentax DSLR Discussion 2 04-18-2008 06:48 AM
All times are GMT -7. The time now is 11:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
