06-02-2016, 03:12 PM   #1
Otis Memorial Pentaxian
photolady95's Avatar
Anyone ever done this before?
I have an older Sigma lens whose rear element went foggy, unable to clean it because it's plastic. Now I have two other Sigma lenses and was thinking since the older lens was particularly sharper at 300mm than the other two, I could take the rear element from one of my other lenses and swap them out. All are Sigma 70-300mm Macro lenses. The older one is an APO model though and the other two, neither is APO nor DG models. All three are AF lenses with same f stops. Would it work?
06-02-2016, 03:28 PM   #2
I haven't done that with those lenses before, but I have swapped rear elements on cheap primes before and it can change stuff alot. I would go for it and see what happens. A fun experiment!
06-02-2016, 03:31 PM   #3
QuoteOriginally posted by photolady95 Quote
Assuming the lenses don't break during disassembly, I think the APO version has different optics than the earlier lenses, so probably won't work.
06-02-2016, 04:19 PM   #4
Thanks for your input Adam. I'm not too worried about breaking them. The APO version has already been disassembled, me trying to clean the rear element and I didn't break it.
QuoteOriginally posted by kmurphy220 Quote
I guess I'm just going to try it.
I'm a computer tech too so I know how to be careful with disassembling equipment and reassembling them.
06-02-2016, 05:16 PM   #5
DeepThrob's Avatar
'plastic rear element' ?
06-02-2016, 07:45 PM   #6
QuoteOriginally posted by DeepThrob Quote
Yes. I was surprised to learn that when I disassembled it to try and clean it.
06-02-2016, 10:33 PM   #7
There isn't a plastic cleaner you can use to clean it? I was speaking to a framer the other day, and they mentioned that you can't use glass cleaner (Windex) on plexiglas (used instead of glass when framing large photos), but there is something else intended for cleaning plastic. Maybe that type of thing would be possible here? I mean, it may be worth a try, if your only other alternative seems to be what you are suggesting.
Lee
06-02-2016, 11:02 PM   #8
I searched for plastic cleaner and found nothing suitable for cleaning the type of plastic in the rear element. Especially when I didn't know what type of plastic it was, I was unsure of what to get.
apo, element, k-mount, lens, lenses, pentax lens, sigma, slr lens
Has anyone seen this haze on glass before? thehabit Pentax SLR Lens Discussion 9 06-27-2015 05:49 AM
Has this ever happened to anyone else? wile Pentax K-5 6 12-07-2014 04:21 PM
Shooting with two 645s - has anyone done this before? dugrant153 Pentax Medium Format 12 08-30-2011 10:15 PM
Has anyone done real estate photography before? jennverr Photographic Technique 19 02-02-2011 07:17 AM
Anyone know how this is done? rwheeler Photographic Technique 10 11-20-2009 02:41 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
