Hi,
I love my Tamron Adaptall-2 300mm 2.8 360B. Great lens, works great with AFA 1.7x. I got many very nice photos from it.
But the lens has a very slight wobble, between the entire rear part and the focus scale ring. Very slight play, maybe 0.5 mm max. But because the lens is so heavy, the slight play makes annoying sounds.
Here are two photos showing the issue. Not very obvious though. 2nd one shows the little space when I lift the lens up by grabbing the rear end. You can see the line above "..5 4 " is slightly thicker.
The lens has been with me for many years, and has always like that, so I don’t think the wobbly barrel could cause any further issue.
I wonder if anyone has seen similar problem, and if it is a possible DIY fix. I have a little experience tinkering MF prime lenses, but of course not at DCshooter’s level.
Thank you!
