Originally posted by GodsPetMonkey If you like I can open my lens up again and take some pictures for you when I get home from work today.
Well, no one asked for it, but I am going to give it anyway. This really is a simple fix!
To start off, you need some equipment:
https://flic.kr/p/HtvsyU
* a bowl
* a pair of tweezers
* a screwdriver (size 0 or 00)
* grease cleaning fluid - I used isopropyl alcohol
* cotton bud
Remove the 5 screws on the baseplate. Make sure you use the right sized screwdriver or you will torque out and damage your screw heads.
https://flic.kr/p/HTZ8qi
Place the lens in the bowl and
carefully remove the baseplate. There is a loose spring underneath you will want to catch and some of the electrical pins may not want to stay in their holder on the baseplate.
https://flic.kr/p/HKeMkQ
Find the tiny gold spring and put it safely in the bowl.
https://flic.kr/p/HtvKbS https://flic.kr/p/HtvQyL
You don't want to lose it! The lens' chip and aperture contacts won't work without it.
Put any loose pins back into the baseplate then store it safely in the bowl.
https://flic.kr/p/GY9woN
Slowly lift the aperture control ring. There is a spring underneath that you need to unhook using the tweezers.
https://flic.kr/p/HMD3nK
That's all the taking apart you need to do. There should be some shiny grease under where the aperture ring sat - I had already cleaned mine before taking the pictures so I have 'painted' a drop of alcohol to show where it was.
https://flic.kr/p/Htw9G9
The grease seemed to have come out of the two holed metal disc on top of the screw drive mechanism. Poor diagnosed had the aperture ring floating over the top of that metal disc, and thus catching the grease.
Clean up the grease, it was pretty easy to remove, remember you don't want to damage anything here!
Be sure to clean any grease on the underside of the aperture ring as well!
https://flic.kr/p/HMDeDT
Putting the lens back together is the opposite of taking it apart. Start by putting the aperture ring back on. The long arm slots into a receiver that open the aperture blades, so make sure you put it in the right spot.
https://flic.kr/p/HMDiKP
Before you finish putting the aperture ring down, reattach the return spring with your tweezers. This is a bit fiddly, but is easier then the ring is being held just above the surface it sits on.
With the ring back in place, gently put the small gold spring back in its position.
https://flic.kr/p/HMDmzX
With the lens in the bowl you can carefully lower the baseplate back on. Make sure you watch the position of the pins to ensure they end up in the right place! None of my pins fell out when doing this, but if yours do the bowl or lens will catch them.
Once the plate is on, screw it down. Don't over tighten the screws. Once tha is done play with the aperture lever, it should be nice and snappy now. Job done. Test the lens of your camera to make sure it is recoding the correct aperture and lens information from the contacts.
If the aperture lever moves but doesn't snap back the return Spring probably unhooked itself, open it up and try again.
If the lens reports the wrong aperture or lens information one of the pins is out. Remove the baseplate, check the pins and carefully replace it.
If the lever is still sticky there is probably oil/grease on the blades themselves. A much bigger job.
