Originally posted by mwilky55 What would you suggest?
I'm a fan of Zeiss and there is talk of a Leitax conversion kit for the ZF2 version of the 2/135. This is a current lens and therefore costs silly money, but this is what I would suggest (seeing you asked).
The M42 Zeiss glass is probably the S mount, the odd lens will appear on ebay with this mount but probably not the 135. If there is reference to a current Zeiss M42 mount lens please note these are listed under their industrial lenses, are even more expensive than a standard T* Zeiss lens and you may need to send your kit to the factory to get it set up correctly (according to one Zeiss rep I spoke with a couple of years ago). I am hoping someone has tried this option so they can tell us how it went with examples/costs etc.
The Contax/Leitax option is worth sometime researching too if you've not already done this.
I'm not an expert on all the Pentax 135 lenses but between the PF database and the people on this forum I expect you will be well covered for feedback/info on these.
There is a Samyang/Rokinon et al 2/135 which is manual focus and I've seen some good images taken with this lens. Apparently QC can be an issue with these lenses but good ones get really good reports around the forum.
I agree that manual focus can be a hindrance at times, but then so can AF if it hunts or misses. I've missed my fair of both manual and AF shots, you have a preference and MF will work for action and low light if you prepare and set up well and accept that sometimes you're just going to miss. What will help is the AF assist system in your camera and the fitting of a focus screen more suitable for manual focusing than the standard one fitted. I use an S type screen purchased from focusingscreen.com. Works great using my Zeiss 2/100.
If you go down the manual focus path and intend one day on picking up the K-1 be aware that the AF assist and focus peaking in LV are a huge improvement over a K5.
Dang, I worte another bl**dy novel.
Tas
