06-16-2016, 09:34 PM   #1
les3547's Avatar
Prime Lens IQ at Different Focus Distances
With a zoom one might see in a review how a lens' IQ varies at different focal lengths.
I've wondered if IQ varies in a prime lens depending on how far or close one is focusing. I have been testing that idea, and it seems to me that focus at infinity typically exhibits the poorest IQ. Other than at infinity, I haven't yet been able to decide much. Is there any wisdom, or studies, that address image quality of a single-FL lens focused at different distances?
06-16-2016, 10:46 PM - 2 Likes   #2
It depends on lens design. Those with floating elements should be best corrected for various focal distances. Those without are likely weakest at minimum focus distance. Perhaps portrait lenses are optimized for that working distance. Process lenses are optimized for 1:1 reproduction.
06-16-2016, 11:52 PM   #3
Fogel70's Avatar
QuoteOriginally posted by les3547 Quote
One problem with testing IQ at infinity is that meteorological visibility (or other weather condition) can vary very much from one day to next.
It may be hard to find a day that has perfect weather conditions for testing IQ.
06-17-2016, 01:55 AM   #4
Infinity focus may be tested good at distances further then the hyperfocal distance. For most normal and wide angle lenses weather wouldn't be a real problem. For tele lenses it may be a problem.
06-17-2016, 02:15 AM   #5
LennyBloke's Avatar
QuoteOriginally posted by civiletti Quote
Good point - If you read about the Pentax A* and FA* 85mm lenses you'll see that some people suggest the A* is superior to the FA* at infinity - different lens designs - is one more of an "all rounder" and the other optimized for portraiture ?
06-17-2016, 07:52 AM   #6
les3547's Avatar
QuoteOriginally posted by Fogel70 Quote
One problem with testing IQ at infinity is that meteorological visibility (or other weather condition) can vary very much from one day to next. It may be hard to find a day that has perfect weather conditions for testing IQ.
Very true. Actually I haven't been able to confirm that infinity focus is worse than any other distance.
I know with my 180mm, I take the worst shots at infinity when I'm shooting hand held (i.e., it's harder to steady the camera), but I do better when focusing at closer distances. That makes me wonder too since doesn't 180mm FL remain 180mm whether one is focusing near or far?
06-17-2016, 08:22 AM   #7
Interesting thread; I've wondered about this issue myself. Just like every lens has a 'sweet-spot' aperture for best IQ (it isn't necessarily f8), does every lens have its own 'sweet-spot' focus distance?
Two cases in point:
1. When using my Pentax-M 50mm f1.7 with either close-up lenses or extension tubes for macro, will I get the best IQ if I focus to minimum, maximum, or in-between?
2. I've read that my Vivitar 400mm f5.6 gives best IQ when focused close to the minimum distance, 13 feet. The problem is that I use that lens for stuff that's far away.
06-17-2016, 07:31 PM   #8
fwcetus's Avatar
QuoteOriginally posted by LennyBloke Quote
I would say that LennyBloke is correct, in my experience (from quite a few years ago).
I will also say (which may or may not be related to the above) that, while the FL of the FA* 85/1.4 is likely close to 85mm (or at least similar to other older Pentax 85's) when focused at close to infinity, it would seem to be a bit less than 85mm (or at least a bit shorter than other older Pentax 85's) at closer focus differences. Take a look -
06-17-2016, 08:03 PM   #9
Even the "best" shows this.
One example I have experienced is with my Leitz 24mm f/2.8 Elmarit-M (the original version made in the '90s). The lens is optimized for near range focusing and just sings wide open focused at 4-7 ft or so. Beyond 15ft or so it begins to decline in sharpness etc. It was made for close distance reportage in lower light situations and Is beautifully rectilinear with as little distortion at the edges as is probably possible with any lens of that focal length. Not to say it is not a wonderful lens at any distance or f-stop, just how it was optimized. I really don't think there is a lens made that will be "superb" at all f/stops and all focus distances. It is the nature of optics. There has to be a "sweet spot" of some kind.
06-17-2016, 08:22 PM   #10
les3547's Avatar
QuoteOriginally posted by jeverettfine Quote
One example I have experienced is with my Leitz 24mm f/2.8 Elmarit-M (the original version made in the '90s). The lens is optimized for near range focusing and just sings wide open focused at 4-7 ft or so. Beyond 15ft or so it begins to decline in sharpness etc. It was made for close distance reportage in lower light situations and Is beautifully rectilinear with as little distortion at the edges as is probably possible with any lens of that focal length. I really don't think there is a lens made that will be "superb" at all f/stops and all focus distances. It is the nature of optics.
Interesting. It would be useful, to me anyway, to have charts for the optimal focus distances for lenses, but that's not commonly part of reviews.
distances, focus, infinity, iq, k-mount, lens, lens iq, pentax lens, slr lens
Super Takumar 50 1.4 with a tight focus ring at close distances W.j.christy Pentax SLR Lens Discussion 6 06-07-2016 08:47 PM
Do different lenses have different minimum temperatures they can operate at? Sagitta Troubleshooting and Beginner Help 10 05-08-2015 09:09 AM
Performance of 645 FA 120mm f4 macro lens at long focusing distances Ed Hurst Pentax Medium Format 16 01-09-2012 10:17 AM
Tamron 70-200 IQ vs 135 prime IQ TOUGEFC Pentax SLR Lens Discussion 21 08-25-2011 05:48 AM
Tamron 300mm f2.8 60B soft at further focus distances? Eruditass Pentax SLR Lens Discussion 9 08-18-2011 02:37 PM
All times are GMT -7. The time now is 10:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
