06-22-2016, 03:04 PM   #1
Backup of the rom data in a lens
Hello,
I found a strange behavior while I was trying to backup the rom data in a lens.
Before a week I prepared for my k-5iis a sdcard with files 00077681.541 and develop.mod and everything worked fine.
Then I read the eep data (LENS ROM DAT CAMERA=>SD) from two lenses: Tamron 90 macro and Sigma 300 macro.
May be 5 days later I have read the data again and surprise... the data was different! I tried a second time to read and the values were the same as previous attempt (but different than the values from before 5 days). They are not totally different but many values are changed. I have read only these two lenses so there is no mistake.
Have you seen this behavior on any lenses and do you have any idea why the values are changing?
Here are the two versions of the first block of the Sigma backup data:
============= -1- Begin =================================================
"; 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F"
":0000", "7C","7C","7C","7D","04","04","06","83","41","FA","02","02","02","83","7C","7C"
":0010", "BE","02","02","83","41","FA","02","02","02","02","FA","02","02","02","02","02"
":0020", "83","41","FA","02","02","02","02","83","41","FA","02","02","02","02","02","02"
":0030", "83","41","FA","02","83","41","FA","02","02","02","02","02","02","83","41","02"
":0040", "02","02","06","83","41","FA","02","02","02","02","02","02","02","83","7C","7C"
":0050", "BE","83","41","FA","02","02","02","02","02","02","02","F9","F9","F9","F9","F9"
":0060", "7D","06","83","41","FA","02","02","02","83","41","FA","02","02","02","83","41"
":0070", "FA","02","02","02","02","41","FA","02","02","02","02","02","02","02","83","41"
":0080", "FA","02","FA","02","02","02","02","02","02","02","02","83","41","FA","02","02"
":0090", "83","41","FA","02","02","02","02","02","02","02","02","83","BE","02","02","83"
":00A0", "41","FA","02","02","02","02","02","02","02","7C","7C","7C","01","02","83","41"
":00B0", "FA","02","02","02","02","02","83","7C","7C","7C","7C","BE","83","41","FA","02"
":00C0", "02","02","02","83","41","FA","02","02","02","02","02","02","83","41","FA","02"
":00D0", "83","41","FA","02","02","02","02","02","02","06","83","41","FA","02","06","83"
":00E0", "41","FA","02","02","02","02","02","02","02","83","94","0D","94","F8","94","08"
":00F0", "94","E3","0D","94","FC","94","08","94","0D","94","F8","94","08","94","E3","0D"
============= -1- End =================================================
============= -2- Begin =================================================
":0000", "02","02","02","02","02","02","02","02","02","02","02","02","02","FA","02","02"
":0010", "02","02","02","02","02","02","83","41","7D","04","02","02","02","02","02","02"
":0020", "83","41","FA","02","02","02","02","41","F9","F9","7D","04","04","06","83","41"
":0030", "FA","02","02","02","02","7D","04","06","83","41","FA","02","02","02","02","02"
":0040", "02","83","41","FA","02","02","02","02","02","02","02","02","02","02","83","7C"
":0050", "7C","7C","7C","7C","BE","02","02","83","41","7D","0D","02","02","02","02","02"
":0060", "02","83","41","FA","02","02","02","02","83","41","7D","06","83","41","FA","02"
":0070", "02","02","02","02","02","06","83","41","FA","02","02","02","02","02","02","02"
":0080", "02","83","7C","7C","7C","BE","02","02","83","41","7D","06","83","41","FA","02"
":0090", "02","02","83","41","02","02","02","02","02","02","02","02","83","41","FA","02"
":00A0", "02","02","02","02","02","02","02","02","02","83","41","FA","02","02","02","02"
":00B0", "02","02","02","02","02","02","7C","41","FA","02","02","02","02","02","02","02"
":00C0", "02","02","83","40","F9","F9","F9","F9","F9","7D","02","02","83","41","FA","02"
":00D0", "02","02","02","83","41","7D","06","83","41","FA","02","02","02","83","41","FA"
":00E0", "02","02","02","02","02","02","02","02","02","02","02","02","02","83","41","7D"
":00F0", "06","83","41","FA","02","02","02","04","04","04","06","83","41","FA","02","02"
============= -2- End =================================================
I have attached both LENSEEP.LNS files.
Thanks
06-23-2016, 10:44 AM   #2
UncleVanya's Avatar
I'm not as familiar with the lenses - are both screw drive or are either of them hsm?
06-23-2016, 01:39 PM   #3
Both are screw drive. These are not newest modern lenses but I think they should contain consistent EEP tables as they are AF lenses.
06-25-2016, 03:25 AM   #4
Nobody has any idea? Really?
06-25-2016, 07:32 AM   #5
UncleVanya's Avatar
Honestly I have never backed up the data except to modify for screw drive conversion. I also have zero non Pentax auto focus lenses at this point in time.
I'm not sure what the value of backing up the data would be with a non Pentax lens - since I'm not even sure it is designed to be written back to the lens based on what you are seeing.
07-14-2016, 07:50 AM   #6
I'm a bit late..
Some Tamron/Sigma and also some Pentax lenses doesn't have a "real" Lensrom.
They "do it" in another way ..not as Pentax normally does.
Those lensroms which you can read out of those lenses are changing if you change the focus or focal length.
There is a thread...started long time ago:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/251464-coll...-lensroms.html
backup, data, k-mount, lens, lenses, pentax lens, rom, rom data, slr lens, values
Request: I would love to see the reading of the electronics level in the meta data PeterL Pentax DSLR Discussion 14 03-30-2016 08:51 PM
help in the election of a sharper wide angle lens Vemobydam Pentax SLR Lens Discussion 65 12-29-2015 11:31 PM
In praise of the venerable Pentax-A 645 55mm f2.8 lens johnmb Pentax Medium Format 2 10-04-2015 04:33 PM
Help Me Spend my Tax Refund (need a camera and maybe a backup or a lens) Sagitta General Photography 24 01-30-2015 01:50 PM
best way to store/backup data while travelling? slartibartfast Digital Processing, Software, and Printing 18 08-01-2012 09:36 AM
All times are GMT -7. The time now is 08:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
