Originally posted by pathdoc Sod's law says life is six to five against. Are you sure Ms New isn't operating in screwdrive mode, having previously been deactivated? (If so, you are safe. If not, the internal noises may point to problems.)
If the SDM fails, it can always be deactivated and you can default to screwdrive.
Thanks for the reply pathdoc. Yes, I'm dead sure it's operating on SDM. It's only very very slightly noisier than the other one. I'm sure it's the infernal parts. I'm aware of the conversion to screwdrive on the K5. Can it be done on the K3 as well?
---------- Post added 06-26-16 at 02:25 PM ----------
Originally posted by Adam Which one have you used more? SDM is more prone to failure if you just leave it on the shelf for extended periods of time.
True. The problem is I only procured them a couple of days back so didn't get a chance yet to use either one extensively...
