07-03-2016, 12:35 AM - 2 Likes   #1
Paul the Sunman's Avatar
My DA Limiteds on the K1
I have finally had a chance to try out my beloved SMC DA Limiteds (15, 40, and 70) on the K1. Although they are all officially crop lenses, the latter two at least have shown signs of being able to migrate to FF. So here are my findings, with representative images.
  • DA 70 Limited definitely FF compatible (1/160, f/8, ISO100)
  • DA 40 Limited little vignetting but a bit muddy in the extreme corners (fine on the edges); useable-to-good (1/40, f/11, ISO100)
  • DA 15 Limited forget it (1/30, f/4, ISO1250)
The DA70 and DA40 were with hoods; the DA15 without. Using the hood on the DA15 vignettes much more.
07-03-2016, 01:00 AM   #2
HYS
Nice post!
07-03-2016, 01:48 AM   #3
BigMackCam's Avatar
Nice results on the DA40 and DA70, Paul! Did you try wider apertures, by any chance?
07-03-2016, 02:00 AM   #4
Yes. There was no noticeable vignetting from either lens even wide open!
07-03-2016, 02:01 AM   #5
BigMackCam's Avatar
QuoteOriginally posted by Paul the Sunman Quote
Fantastic. Those will be nice focal lengths on FF
07-03-2016, 02:12 AM   #6
Nice. A good central composition with the DA40 should draw the viewer's eye away from any dodgy areas. I haven't got extensive experience with it on film, but nothing I've ever photographed with it seemed to show any particular problems.
Slightly OT, have you got and tried the DA50/1.8? It worked acceptably for me on film. I would use it on my newer film bodies, but on everything except the Super Program I am in auto-only mode and can't really make best use of it - and the same applies to the DA Limiteds, of course.
07-03-2016, 02:45 AM   #7
Tas
DA70 vignette
Hi Paul,
Lovely detail in the helicopter there mate. I've always had a sweet spot for the DA70.
It's interesting that you didn't get any vignetting on the DA70 wide open as I did find it on my SMC version of that lens. Nothing bad of course and easy to fix. I've only been out once with the K-1/DA70 and didn't shoot the lens stopped down too far. From that one trip I found vignetting present down to f5.6.
f2.4
f5.6
Tas
07-03-2016, 02:53 AM   #8
Interesting.
You wonder if perhaps they changed things between the SMC and the HD variants in a way that made a difference.
Those with access to a K-1 and examples of both SMC and HD versions are invited to compare and comment...
07-03-2016, 03:01 AM   #9
QuoteOriginally posted by pathdoc Quote
My son has the DA 50 f/1.8. I just threw it on the K1 for a quick test. There is a little darkening in the corners, but this is largely cleaned up by applying lens correction in LR. Here's an uncorrected image (f/2.2). I'm afraid the lighting isn't completely even, but you get the idea.
07-03-2016, 03:05 AM   #10
bxf
bxf's Avatar
It's worthwhile keeping in mind the possibility that even when there are some limitations in using some DA lenses on FF, the useable area may be larger than what one would obtain using CROP mode, so that cropping in PP would be the better option.
07-03-2016, 03:06 AM   #11
QuoteOriginally posted by Tas Quote
OK, at f/2.4 there is some minor corner darkening, but this is pretty well cleaned up by profile corrections in LR.
07-03-2016, 04:51 AM   #12
Tas
I don't mind the vignette personally, and as you say it can be sorted in post easily. The DA70 is a great lens and it's well worth using on the K-1, something I think we both agree on.
07-03-2016, 05:27 AM   #13
The DA 70 vignetting wide-open hardly seems noticeable.
Vignette seems part of the FF 'look'. Which is good, because I think folks will be hard-pressed to find ANY fast FF lens that doesn't vignette noticeably wide-open. Go through Lenstip.com and have a look at the vignetting tests for a few fast FF Nikon's, Sigma's and Canon's (eg Sigma 35 f1.4 if you want to see real FF vignetting), or look at a few long FF telephoto lenses.
07-03-2016, 05:33 AM   #14
Hmm... I only took a snapshot or two, but I'm not happy with my SMC DA 70mm border performance on FF. I've put it on my "to replace" list.
07-03-2016, 05:36 AM   #15
micromacro's Avatar
SuperTak 50mm f1.4
da, da limiteds, da15, ff, iso100, k-mount, k1, limiteds, pentax lens, slr lens
To K1 or not K1 - that is the question? interested_observer Pentax K-1 78 07-15-2017 03:58 PM
FA Limiteds on the K-1 MadMathMind Pentax K-1 18 05-23-2016 03:50 AM
Lloyd Chambers comments on the HD DA Limiteds David&karen Pentax SLR Lens Discussion 4 11-15-2013 04:13 PM
DA Limiteds at my university's shoot soccerjoe5 Pentax SLR Lens Discussion 28 03-24-2009 09:43 PM
filters on the DA limiteds soccerjoe5 Pentax SLR Lens Discussion 3 09-01-2008 04:48 AM
All times are GMT -7. The time now is 09:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
