Originally posted by Wheatfield As a general rule, I stay away from anything KPR (Ricoh) because of potential problems with the mounts being slightly incompatible. KzPR can have a slot in the mount that can foul the AF key and cause the accessory to jam.
I don't know if this is something to worry about with the tubes, but I would inspect the mount closely to ensure it is identical to the K mount before using it.
The offending part (the Ricoh Pin of Stuckness) is a small protruding pin on the mounting flange that's almost directly opposite of the red dot (if you're looking at the base of the lens, and place the red dot at the 12:00 position, the pin is at about 6:20).
Just to make things even more confusing, there's another lens mount that has a contact in the same position but doesn't get stuck (e.g. old Vivitar lenses with the "PK-A/R" mount).
It might be possible to disassemble the extension tubes (all three
) and remove the offending pins; however, I wouldn't take a chance on this unless I could get the extension tube set at a
very good price.
Reason: added PK-A/R note
