07-19-2008, 09:18 AM   #1
hrishi's Avatar
M 100/4 Macro with flash
Hello,
I have borrowed a M 100/4 Macro for few days..It works fine in natural light, but when I fire the built in flash, it's metering goes all wrong-In 'X mode' it overexposes at f4 and then underexposes consistantly with smaller apertures (correct exposure at f11)...
In 'Av mode'+ builtin flash, it overexposes at all exposures (I think it gets fired wide open even if other apertures are set on the ring)..Has anybody tried this lens in Av mode with an external flash?
In 'M mode', even when the builtin flash is fired, the shutterspeed is of a natural light..but the exposure is correct..
this lens is in Mint condition and is offered to me for $200...I shoot BUGS and BUGS only! So is it worth it? I cant see the point of buying a macro lens which can't be used with a flash..
the super takumar 50/4 which I'm offered for $88 has given me very good results with the built in flash like this one
I need a more focal length than 50mm, but considering the M100/4's inability to work with the builtin flash at other exposures than f11, I don't think its worth $100 more than the Sup Tak?
If it works well with external flash, i'll buy it. If not, I wont!
07-19-2008, 11:07 PM   #2
Canada_Rockies's Avatar
QuoteOriginally posted by hrishi Quote
Hello,
The newer P-TTL metering is disabled with lenses that do not have the A setting on the aperture ring. The options then become using a flash that has automatic settings using its own sensor rather than the camera sensor or using the guide number system to set the aperture on that lovely 100/4 M series macro you have.
07-19-2008, 11:42 PM   #3
Blue's Avatar
The built-in flash isn't going to work with macro at least not very well. $200 is over half way to a AF sigma 105mm macro . . .
07-20-2008, 12:12 AM   #4
sewebster's Avatar
Maybe this is obvious, but I screwed it up once. It seems that when you activate the flash the shutter speed is dropped down to your max sync speed (1/180s or something). In Av mode it won't change the aperture to compensate so you get overexposure in a lot of conditions (where there is a lot of light). Even if you stop down, if it is really bright, you might have to stop down a long way...
07-20-2008, 05:35 AM   #5
Lowell Goudge's Avatar
Canadian rockies has it right.
The built in flashes only support p-TTL mode.
YOu would need a flash with auto setting, use the flash manually, or switch to an *istD or DS and external flash that supports TTL
apertures, bugs, exposure, exposures, flash, k-mount, lens, macro, mode, overexposes, pentax lens, slr lens
Pentax 100 WR macro vs Sigma 105 macro GSk Pentax SLR Lens Discussion 7 03-22-2010 04:23 PM
For Sale - Sold: Pentax AF360 Flash and Sigma 70-300 Macro Lens - $100 Ari Sold Items 2 12-01-2008 11:09 AM
Not sure which flash to choose from under $100 aweir Flashes, Lighting, and Studio 5 06-06-2008 04:57 AM
D-FA 100/2.8 Macro vs other macro lenses? jankok Pentax SLR Lens Discussion 12 10-25-2007 09:01 AM
All times are GMT -7. The time now is 01:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
