So here are a couple of examples I did this morning while working in the yard. All straight OOC with only crops and whatever resizing happens between me and the PF uploader...
The first is a Beetle my daughter found, happily munching on some Lantana.
It does a good job of showing how the lens does when playing macro. This one was manually focused, which is a trick hand-held at 300mm. ISO was 1600 to avoid camera shake. The original was cropped square, about 9Mp
100% closeup:
And some bricks across the street. Plenty of resolution... there's also lots of resolution in the shingles in the original...
And some fringing at 100%... particularly on the metal strap. Not as bad as it could be since it was stopped down a bit
I hope that's helpful...
-Eric
