Originally posted by Cuthbert I would recommend a K 50mm f1.4, not a M.
The K with Thorium glass is IMO superior...besides that I consider the K55mm f1.8 better than the M/A 50mm f1.7.
The "M" line {and the following "A" line} came about because Pentax wanted to reduce the "heft" of lenses;
the lenses are shorter than the corresponding "K" and preceding "Super Takumar" lines, use narrower plastic rings instead of the heavy-weight metal people were used to, and they also used a different glass.
Even though these lenses are over thirty years old, they feel "modern".
Pictured below are the three 50mm prime lenses I happen to own.
My understanding is that the "K" line basically updated the "Super Tak" line to the then-new K-mount, so if I had a "K" 50mm lens, it would be roughly the same size as the "Super Tak", longer and perhaps 50% heavier than the more modern lenses.
On the far left is a "Super Tak" 50mm f/1.4 that I bought recently on eBay. The price was good, and I was in the process of buying several M42 lenses just in case the Aperture Control malady hit my K-30, but I don't have much actual experience with it.
In the middle is the "M" 50mm f/2 which was kitted with my ME SE when I bought it in 1979. My sense is that it isn't quite as sharp as the A 50 f/1.7, but I haven't actually tested it. The ME SE ended up in the dump after it got damp at Niagara Falls, but I kept this lens to backup the A 50 f/1.7 ... and I've kept it ever since. I have to admit that I've basically ignored it all these years, so I can't really provide much of a "reference" for it.
On the far right is the "A" 50mm f/1.7 which was kitted with my Super Program when I bought it in 1984. The aperture ring tended to stick between f/8 and f/5.6, but the lens provided reliable service to me for eleven years {I had only two lenses, this one and a Vivitar zoom telephoto, so this one was on the camera most of the time}, so I would have to say that it more than passes the build-quality test. When I came back to Pentax by purchasing a K-30 last year, this was the first old lens I tried on the K-30; I was very pleasantly surprised by the sharpness of the pictures.
