As others have said above CA is dependent on the optical construction of the lens - apochromatic lenses are designed to magnify red/blue/green by the same amount* so they produce as little CA/fringing as possible - however, they are extremely rare at focal lengths wider than 100mm. With an achromatic** lens which are much more common at focal lengths below 100mm the blue and red spectrum are often corrected, but the green/magenta spectra is usually out of kilter***. As focal length gets longer, this deficiency becomes increasingly obvious And close focusing only exacerbates the differential in magnification, which is why it is better to stop down at minimum focus distance as nearly all lenses are optically compromised at MFD.
Filters will have no effect on CA.
*Or as near enough as physically possible.
**A precusor of the apochromatic lens, achromatic lenses are only corrected for two wavelengths of light - typically red/blue. Apochromatics are corrected for three wavelengths. Super-apochromatics are corrected to focus four and sometimes five wavelengths at the same plane.
*** Fringing can appear in different spectra too, green/magenta, yellow/blue, blue/red fringing are rather common.
