Originally posted by timb64 And your argument is against sharp lenses?!That looks the definition of a sharp image.
My argument is that most of the lenses of the film era are sharp enough.
Excessive sharpness of the new "digital" lenses are counterproductive as they create sterile images.
For the record the Helios 44m-4 was rated by the Soviets with are resolution of 41 lines/mm in the centre and 20 in the corners, they improved that lens until the Mk7 reached 50/30, similar to the Zenitar 50mm f1.9.
Do you need more?
Originally posted by Nickrs I think Cuthbert had drifted off sharpness and onto the Helios-44, which was probably my fault, I still love his picture though and agree it is very sharp. In fact I might get my Helios-44 out tomorrow, I have a fancy to photograph some bees.
Yes that's the point, other examples of sharp pictures from old lenses:
1962 Industar 61 with Leica IIIb, BW400CN:
(I didn't even meter this shot)
CZJ Sonnar 200mm f2.8 wide open, Praktica VLC3, XP2
Flektogon 35mm f2.4, Praktica BX20, XP2...a guy in the film forum said this is a good lens but soft at the corners.
So the point is...can these newer lenses make better pictures than these? Are they sharp enough?
Also, I don't use PP, the scans are from a minilab....what you see is what you get.
