07-27-2016, 06:00 PM   #91
slip's Avatar
https://www.dpreview.com/forums/post/54105302
07-27-2016, 06:59 PM   #92
Paul the Sunman's Avatar
QuoteOriginally posted by krazykat Quote
I am under the impression that allowing Electronic First Curtain Shutter might ameliorate the phenomenon but not be a complete cure.
Well, the K-1 is certainly physically capable of EFCS, as it uses it in pixel-shift. Maybe it only needs a firmware update to allow it generally. I think we have seen in this thread that it would be a valuable feature.
07-28-2016, 05:16 PM   #93
Hi all, I've checked in Lightroom my 250+ photos that have shutter speed between 1/80 - 1/160. None of them have motion blur or double image. I do not think this is a common problem.
edit: Hi all, after a close examination again, I find that two images out of 101 taken with K1+DFA 28-105 lens at 1/100s have some double image blur...Too bad it's there! Sorry I should have be more careful before I posted previous comment.
07-28-2016, 06:27 PM   #94
Actually, I think it is common, but not universal.
---------- Post added 29-07-16 at 11:30 AM ----------
QuoteOriginally posted by David L Quote
Which lens, and which focal length?
07-28-2016, 06:38 PM   #95
Sandy Hancock's Avatar
My DFA15-30 does the same thing - randomly blurry hand held shots despite adequate shutter speed, stopped down, accurate focus and good hand-holding technique. With SR turned off results are tack sharp.
These rather boring test shots are uploaded to flickr at full size for those who are interested.
SR on:
Mr Hyde
SR off:
Dr Jeckyll
And here is a month's worth of shots taken subsequently, almost invariably hand held, with SR off, and some in quite low light.
Single in July 2016
Ricoh really needs to sort this out.
07-28-2016, 07:02 PM   #96
Weather permitting, I'll compare SR on and off on the weekend. But your Mr Hyde does look familiar. I'm guessing it's worse though at around 1/100 sec.
We don't even know if Ricoh is aware of the problem yet.
07-28-2016, 07:21 PM   #97
SR off:
Just a quick one Sandy, in the comments for Dr. Jekyll on Flikr you've stated that SR was on but here you've stated it was off. I can't see the EXIF to check.
07-28-2016, 08:24 PM   #98
I don't think this affects all camera bodies, either- at least not in a significant way. Some shutters might cause more vibrations than others, perhaps due to manufacturing tolerance.
07-28-2016, 09:12 PM   #99
Otis Memorial Pentaxian
clackers's Avatar
Around 1/100s suggests shutter shock:
A Thousand Words A Picture: Mirror-Slap Versus Shutter Shock
07-28-2016, 09:30 PM   #100
Ah! Well spotted. It was a while ago and I had forgotten. They were both with SR on, with very different results despite identical conditions. After the discussion around these two shots I have tried to remember to turn SR off every time I used the lens, with totally consistent and high quality results.
---------- Post added 29-07-16 at 02:06 PM ----------
Interesting. I'm pretty sure I have seen it at considerably faster shutter speeds as well, but I'll look into it.
07-28-2016, 10:32 PM   #101
07-29-2016, 08:18 PM   #102
I tried some tests this morning, with various lenses and various focal lengths. Camera on tripod, IR trigger with 3 sec delay, shooting boxes with text on them from 1-2 metres.
  • Using D FA 28-105 @ 28mm, SR on, focus left fixed at point where 1:1 image very sharp at 1/500 sec: a little soft at 1/60 to 1/125 sec or even 1/200;
  • Generally better with SR on;
  • Slightly reduced effect at 48mm; again better with SR on,
  • Softness absent with D FA* 70-200 at both 70mm and 160mm -- this is a very heavy lens that seems to stabilize the camera.
However, I was only seeing softness, not the "double image" I sometimes see hand-held. That seems to be characteristic of very complex scenes (such as vegetation), which suggests to me a focussing issue rather than purely camera shake.
I don't feel I fully understand this camera yet, but shutter shake is certainly identifiable in my tests.
07-30-2016, 02:41 AM   #103
Ole
Ole's Avatar
QuoteOriginally posted by Paul the Sunman Quote
I'd speculate that a good tripod would suppress the vibrations just enough that the double image doesn't show but becomes blur.
blur, bokeh, branches, camera, crazy bokeh, d fa 25-105, day, effect, exif, fa, image, images, k-mount, k1, k3, lens, lightroom, look, motion, pentax lens, pixel, post, reeds, shift, slr lens, speeds, sr
D FA 28-105 better IQ than D FA 24-70 PhilRich Pentax SLR Lens Discussion 26 07-28-2016 06:30 AM
Problem with K-1 and D FA 28-105? StevenLS Pentax K-1 & K-1 II 3 06-25-2016 10:38 AM
Pentax D FA 28-105 on K-1 - any experience? 6x7 Pentax SLR Lens Discussion 9 06-25-2016 07:40 AM
HD D-FA 28-105 leaked online banep Pentax News and Rumors 189 03-10-2016 10:02 AM
Dropped my lens. Need help figuring out the problem. geomez Troubleshooting and Beginner Help 3 05-21-2013 05:02 PM
All times are GMT -7. The time now is 10:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
