07-21-2008, 02:54 AM   #1
another neophyte question
Hello,
So, I have this 28-80/3.5~4.5 Pentax A lens. The focusing circle at the center of the viewfinder is horizontally divided into two hemispheres and depending on the situation either one of these areas becomes partly or completely dark. I intuitively suspect that this signifies me that something ain't right, that I shall change my POV a tad in order to correct this. Am I right? Is this behaviour a common thing in all lenses? Cause I've noticed that with a 50mm/1.7 prime (used with a Minolta xg9) this does not happen.
Enlighten me on this, please.
07-21-2008, 06:24 AM   #2
Wheatfield's Avatar
QuoteOriginally posted by lazyeye Quote
Hello,
Split image focusing aids go dark at smaller apertures, generally they become useless below f/4. Your 28-80 qualifies in this category. You might find that if you very carefully place your eye centered in the finder, both sides of the split will stay bright, but it isn't likely, especially at the longer focal lengths where it is slower than an f/4 lens. It didn't happen on your Minolta because you were using a lens several stops brighter.
07-21-2008, 08:31 AM   #3
Hello,
Try setting the aperture to f5.6 and push the DOF preview button on your XG9 and you will see the same behaviour.
Jan
07-21-2008, 09:22 AM   #4
ok, thanks both of you.
You're right, Wheatfield, just moving my eye, and not the camera, a tad and the viewfinder's center stays bright.
k-mount, pentax lens, slr lens
Pentax Neophyte Todd Adamson Welcomes and Introductions 5 10-22-2010 01:54 PM
Need Suggestions: RAW? Trek, PP Neophyte Biff Digital Processing, Software, and Printing 6 08-28-2010 04:19 PM
Hi, new here and a question ... eSFotos Pentax Film SLR Discussion 12 05-25-2009 04:46 AM
Neophyte question lazyeye Pentax SLR Lens Discussion 13 07-20-2008 05:47 AM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 07:30 AM. | See also: NikonForums.com, part of our network of photo forums!
