07-21-2008, 09:42 AM   #1
dgsullivan's Avatar
Looking for Extreme Fisheye Lens
This there anything near a 5mm FE for Pentax mount?
I have a Lomography FE film camera that produces similar images to Sigma's 4.5mm FE, but they do not make a Pentax mount of this.
Thanks.
07-21-2008, 10:45 AM   #2
pentagor's Avatar
I think that the widest you can go is 8mm: PELENG
07-21-2008, 12:03 PM   #3
sharko's Avatar
I was recently outbid on ebay for an old 8mm circular fisheye lens from Sigma. I doubt it would have the black area all around the image but I'm sure the effect would be more pronounced that the current DA 10-17mm.
07-21-2008, 12:58 PM   #4
Sigma makes an 8mm as well.
07-21-2008, 06:57 PM   #5
Wheatfield's Avatar
QuoteOriginally posted by dgsullivan Quote
Thanks.
The shortest lens that I believe has ever made was the 6mm/2.8 Nikkor. It had a field of view of 220.
There may have been an Alpa lens that was shorter still, but I am too lazy to google it.
If you really need something that wide, the you may as well buy a body to go with it. The camera will be the least expensive part of the purchase by probably a factor of 10.
07-21-2008, 08:38 PM   #6
dg,
As you know the Sigma 4.5mm f2.8 is one extreme lens, and I'm always amazed by the images it produces.
Sigma would most likely make this lens in a Pentax mount, if there was enough demand for it.
If everyone here interested in it was to write to Sigma requesting it the I would imagine that there's a chance.
The other option I can see is. If you'll be looking for a second body in the near future you might want to look at the Sigma SD14.
You can run most of the Pentax manual focus lenses on it with a small mod, and they still work just about as good on the Pentax.
Even better in a way, since you can use AV
And the SD14 is very affordable at the moment, I believe that it's less than $700.00 USD.
I shoot both Sigma and Pentax. And in my personal opinion they compliment each other.
fe, k-mount, pentax, pentax lens, slr lens
Extreme Telephoto/Mirror Lens? Julie Pentax SLR Lens Discussion 4 09-05-2010 04:38 PM
Extreme wide angle portraits (not fisheye) levelred Pentax SLR Lens Discussion 22 04-09-2010 11:30 PM
Fisheye lens RussellW Pentax SLR Lens Discussion 15 06-28-2009 04:53 PM
Fisheye Lens Orli Troubleshooting and Beginner Help 15 03-08-2009 12:04 AM
What FishEye lens is Better. Fl_Gulfer Pentax SLR Lens Discussion 16 02-12-2008 08:18 PM
All times are GMT -7. The time now is 05:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
