Originally posted by Oricman I've got a K30. K30 seem to have a few issues. I'm thinking of picking up a K5iis if I can find one at a good price.
Lenses so far are the WR kit lens, DA55-300. (Also picked up a Tamron 70-300 macro when the 55-300 was faulty) And the Sigma 17-70 OS HSM.
So I've only got zooms which all can be a bit soft at one end or the other. Something sharper and wider is basically what I'm after.
I do not think most wide-angle zooms will be sharper than the 55-300mm - which I also have - and the kit zoom lenses. Probably the best two options that might be good for you= the Pentax 12-24mm and, especially, the Pentax 14mm! However, the 12-24 will be replaced soon and the 14mm is not wide enough for me and many others! (I find myself shooting the Sigma 10-20mm mostly at the 10-12mm end of things!). FYI, I have the Pentax K5II, K5IIs, and the K30. Very little difference - same sensor- in picture quality between them, especially when using the Sigma 10-20mm, 18-55mm, and the 55-300. Especially disappointed by the K5II vs. K5IIs, since I cannot discern a real difference. Maybe if I had some of the better primes - 14mm, 31mm, etc.??? Biggest difference between the K5's and K30, is the build quality IMO, but have not tested the K30 in the same extreme conditions I have used the K5II/s in yet. (used the K5II/s in blistering cold and snow last year in Canadian Rockies at -15 to -25 F, when many Nikon D810's and D800e's failed temporarily, until warmed up!)
